Help with misfire
#48
Have you checked your O2 sensors?
My theory is long, because I went through everything summer of 2010, but when I finally got to the O2 sensors I had one arcing out because of a chafed wire
The problem with our trucks is everything is connected, the problem with the engine may not always be located on the engine.
#50
#51
#54
#55
FIXED!!! Call this thread closed!!! Took every injector out, and tested resistance, all good. Took every spark plug out, checked resistance, all good. Took every coil out, checked resistance, all good. The boots were decent, but there was moisture under them. Got new boots and springs, cleaned out every coil chamber and put it all back together with lots of dielectric. All is well. Thanks for all the help everyone!! Hope this helps someone else in the future.
#57
YES IT DID...
Having issues with mine. Going to remove EVERYTHING tomorrow. and CLEAN it all. Grease it up. b4 I go spending $$$.
thanks for post
paulcalif
1999 to 2016 Super Duty
07-18-2010 10:09 PM
Rukmns
Modular V8 (4.6L, 5.4L)
05-21-2004 12:30 AM
