Help with misfire - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Help with misfire
  #46
Old 01-02-2012, 01:47 PM
PA-Mark's Avatar
PA-Mark PA-Mark is offline
PA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputation
the main thing it turns out to be with no check engine light on is moisture under boot, corrosion
  #47
Old 01-02-2012, 01:48 PM
NorthTitan33 NorthTitan33 is offline
NorthTitan33 is starting off with a positive reputation.
Ya I think I'll change spark plugs and boots. After I do all those tests.
  #48
Old 01-02-2012, 05:43 PM
1973Ford2004 1973Ford2004 is offline
1973Ford2004 is gaining momentum as a positive member of FTE.
Have you checked your O2 sensors?
My theory is long, because I went through everything summer of 2010, but when I finally got to the O2 sensors I had one arcing out because of a chafed wire
The problem with our trucks is everything is connected, the problem with the engine may not always be located on the engine.
  #49
Old 01-02-2012, 06:32 PM
PA-Mark's Avatar
never thought of that.... good lookin out
  #50
Old 01-02-2012, 09:28 PM
well i was out for the night and just got back so no further improvements. ill continue tomorrow. i did notice that one of my rubber boots is different from the rest. maybe they are crap.
  #51
Old 01-03-2012, 02:56 PM
so I am in process of cleaning everything and there was corrosion between the coil spring and the coil, do i put the dielectric grease on everything? even up in the hole where the spring attaches to the coil?
  #52
Old 01-03-2012, 03:25 PM
2003 f-250 2003 f-250 is offline
2003 f-250 is starting off with a positive reputation.
can't hurt anything. All the dielectic grease does is keep out oxygene and moisture.
thanks,
robert
  #53
Old 01-03-2012, 03:45 PM
you all also covered your boots in the grease and then put them down in the hole?
  #54
Old 01-03-2012, 04:46 PM
PA-Mark's Avatar
Quote:
Yes this is fine as well, will do the truck good....
  #55
Old 01-03-2012, 08:45 PM
FIXED!!! Call this thread closed!!! Took every injector out, and tested resistance, all good. Took every spark plug out, checked resistance, all good. Took every coil out, checked resistance, all good. The boots were decent, but there was moisture under them. Got new boots and springs, cleaned out every coil chamber and put it all back together with lots of dielectric. All is well. Thanks for all the help everyone!! Hope this helps someone else in the future.
  #56
Old 01-04-2012, 10:57 AM
PA-Mark's Avatar
Sweet! now dont be a turd and dissapear untill the next problem you have with your truck. Stick around and pay it forward!
  #57
Old 05-26-2014, 06:23 PM
bohiaa bohiaa is offline
bohiaa is starting off with a positive reputation.
YES IT DID...
Having issues with mine. Going to remove EVERYTHING tomorrow. and CLEAN it all. Grease it up. b4 I go spending $$$.
thanks for post
1999 5.4 random misfire, chasing my tail Bootlegger's Deluxe Modular V8 (4.6L, 5.4L) 2 03-12-2016 09:51 PM
2004 Ford F150 5.4 Triton 3V Vin5 Rough Idle Cylinder 3 Misfire Wildboy402 2004 - 2008 F150 12 12-24-2015 01:42 AM
truck sputters swascott1981 Ranger & B-Series 11 03-21-2012 06:02 AM
2004 Ford 5.4L 132k new plugs, system to lean ChrisCarter Modular V8 (4.6L, 5.4L) 9 03-10-2011 01:54 PM
Help!! No Start...Cranks, Sputters, and Dies......First PSD! F350Scott 1999 - 2003 7.3L Power Stroke Diesel 18 05-12-2009 11:59 AM
Tags
2003, 2007, duty, expidition, f250, ford, misfire, northern, piercing, probe, super, tool, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
