C6 Hard Shifts - Ford Truck Enthusiasts Forums
C6 Hard Shifts
Old 12-31-2011, 01:58 PM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
dakotajeep is starting off with a positive reputation.
C6 Hard Shifts
I am experiencing hard shifts as though the vacuum is not fuctioning properly. 1-2 at 30 mph and 2-3 at 50 mph.
I checked the vacuum and its pulling 24" constantly. So its not the vacuum pump.
I verified everything else that is run off vacuum and they are all at 24" ish. No leaks...
When I connect the vacuum gauge to the trans side of the VRV it shows 14" at idle. If I run the throttle the vacuum decreases to less than 14" the more I increase the throttle.
Is that normal? I am starting to think it could be the VRV? Should I adjust the modulator on the rear of the trans?
Thanks
Thad
Old 12-31-2011, 02:23 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
You should get around 20in out of the VRV at idle. Maybe try adjusting it.
Old 12-31-2011, 02:34 PM
dakotajeep's Avatar
Quote:
14" is max. I have tired to go higher but thats it. It goes way lower than that too!
Thad
Old 12-31-2011, 03:39 PM
I assume that you checked that you are getting 24in at the inlet to the VRV? If so it would seem likely that you need to replace the VRV.
Never heard anyone mention it but I wonder is it possible to service one, just a thought.
Old 12-31-2011, 03:53 PM
dakotajeep's Avatar
Yup...might have to spend more cash...
I plan to install a vacuum gauge soon too. Maybe Monday.
Thad
Old 12-31-2011, 04:42 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Is your kickdown linkage well lubed and moves freely?
When I bought my motorhome back in 2000, the man was told by a shop it needed a new tranny as it was shifting at max RPM for each gear.
When I got home with it, first thing I checked was that kickdown rod, and yup, it was stuck down, making the tranny think it was being given full throttle all the time. Good can of WD40 fixed that!
Old 12-31-2011, 04:52 PM
dakotajeep's Avatar
My kickdown rod is not installed. Which way should the kickdown lever be (on the trans) to ensure that this isnt an issue?
Thad
Old 12-31-2011, 04:57 PM
Ah, theres your problem
Having no kickdown rod won't do any bad to the trans, but it will make it shift at max RPM's!
And it's to dark now to see tonight, but if no one knows by tomorrow, I'll run out to the van and check for ya.
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
With a properly adjusted vrv you do not need a kickdown rod. I took mine off because it was still allowing the trans to kickdown too soon for my liking, I like more of a forced kickdown to where I have to deliberatley put the smoke pedal in the rug to do so, that way I can use the lower end power of the motor. The lever on the trans should be forward and up, try tipping the vrv towards the front of the truck a little and see if that doesnt help
Oh and you should be able to pull the lever down by hand and it should spring back up.
Old 12-31-2011, 07:31 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
This is true. The vrv can be used to adjust the shift pionts as well. There are 2 7/16" head bolts that hold it down tight. I played with mine over a 10 mile back roads run and got it to shift right where I wanted it to shift.
Old 01-02-2012, 11:39 AM
dakotajeep's Avatar
I bypassed the VRV and ran vacuum straight to the modulator and now it shifts...but super early. I also put a purple stripe modulator (they didnt have a black one) that I used to further isolate the problem.
At this point it seems to be the VRV and I have one on order. Should be here in a few days. I will shift manually if I need to use the rig over the next few days.
Thanks
Thad
Old 01-17-2014, 07:17 AM
pat420swed pat420swed is offline
pat420swed is gaining momentum as a positive member of FTE.pat420swed is gaining momentum as a positive member of FTE.
I've got some questions, I'm having the same problem exactly as what the op described. I just don't know what I'm looking for. I know when I brought it home I whent under and pulled the hose off the thing at the back end of the tranny and there was just a small drop of oil in there, what is the thing that had the hose on it called and does oil in it mean it's shot?
Also my kickdown is a little rusty I'll check that out today, how do I know if the kickdown is working properly?
Shift Points? OldCharro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 04-20-2015 10:36 PM
c6 shifting behavior and vrv adj bolt size jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-08-2014 09:43 AM
VRV test ozdatman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-20-2013 01:43 AM
C6 VRV Adjustment bgab3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 07-12-2013 01:21 PM
shift problems 79sparky Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 05-08-2013 03:29 PM
Tags
1985, 69, 73, bypassed, c6, diesel, fi50, ford, hard, idi, kickdown, rod, shifting, shifts, vrv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
