Wheel offset - Ford Truck Enthusiasts Forums
Wheel offset
Old 12-31-2011, 07:55 AM
roadkingfl's Avatar
roadkingfl roadkingfl is offline
roadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to all
Wheel offset
What is the correct wheel offset for 2011 F350? I'm looking at buying some new wheels, and, there are 4 or 5 wheel offsets available for the wheels I'm considering (Fuel Octanes). One of the sales people said that 150 is standard for my truck.
Old 12-31-2011, 08:45 AM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
The wheel offset you want will also depend on the wheel width you pick.
Are you wanting the wheels to stick out past the fenders? If so, how much?
What diameter wheel do you want?
What size tires are you going to use?
Old 12-31-2011, 08:50 AM
roadkingfl's Avatar
Quote:
Are you wanting the wheels to stick out past the fenders? If so, how much? No more than they currently do 1" or 2".
What diameter wheel do you want? 18" dia. x 9" wide.
Nitto Terra Grapplers 297/70r18, on truck now.
Thanks man.
Old 12-31-2011, 09:03 AM
Andrew010's Avatar
Currently I have 20x10 wheels with a -18 offset (4.79 Backspace). They stick out 2-2.5"
Next set of wheels are going to be 22x9.5 Fuel hostage wheels with a -6 offset (5.00 Backspace) and will stick out about 1.5-2".
A 18x9 with 5" backspace should stick out 1-1.5" give or take a bit.
All this of course is based off my current wheels and how they "appear" to stick out. Depending on where you measure what from. I'm basing my measurements from the center of the wheel opening above the tire.
Old 12-31-2011, 09:52 AM
brandon4 brandon4 is offline
brandon4 is gaining momentum as a positive member of FTE.
Mine are 20x10 -25mm, 4.5 backspace. Its a bit of a crapshoot the more negative you go. I have a 2.5" lift 35s as I wanted to stay low enough that a four year old could reach the door handle. I had to trim the fenders slightly behind the tired and space the front bumper out 1.5 in. I like thelook sticking out, others may not. I also get lots of crap on the side windows flipping up.
Old 12-31-2011, 10:39 AM
darren32's Avatar
darren32 darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
as far as I know the stock 20" wheels are +40mm offset. I went with- 12mm offset on my new wheels which put the rims out 52mm from stock (2").
Thanks
Old 12-31-2011, 02:02 PM
Andrew010's Avatar
Quote:
Thanks
That would be true with both wheels were the same diameter. Problem is, they're not.
Stock wheels I believe are 8" wide and your 20s are 10" wide.
Offset is based off the center line of the wheel. The center of the wheel is different on different width wheels.
You could compare the 2 on backspace, then do the math to figure out how much wheel is forward of the hub. Then compare those 2 numbers to tell how much further the new wheels will stick out past the stockers.
Old 12-31-2011, 02:14 PM
darren32's Avatar
yaya, sorry, the TIRE moves out 2", the WHEEL moves out 3"
Old 12-31-2011, 07:07 PM
strokinbeast strokinbeast is offline
strokinbeast is starting off with a positive reputation.
I am running a -24 offset on 20x10 Fuel kranks with 37x13.50 tires.
Old 03-08-2017, 09:07 PM
Noah Bishop Noah Bishop is offline
Noah Bishop is starting off with a positive reputation.
What lift? Are you running I'm running 3.5
Quote:
What lift are you running to do that?
Old 03-08-2017, 09:24 PM
Painted Horse's Avatar
Painted Horse Painted Horse is online now
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Mine are 20x9 with a -12 offset. I have no rubbing with 295/65R20 tires or my current 35x12.5x 20 tires
Old 03-08-2017, 09:48 PM
cappa cappa is offline
cappa is gaining momentum as a positive member of FTE.
Quote:
Got any pics of how much they stick out? That is the same setup I am thinking of going with. You running fender flares?
Old 03-08-2017, 09:58 PM
From the back looking up the side of the truck
Side view let you see they are a 35" MT tire
From the front looking back
Old 03-08-2017, 11:27 PM
rickbrad rickbrad is offline
rickbrad is starting off with a positive reputation.
Do you have any pictures showing the flush mounted lights? I have a very similar truck to yours and am thinking of some of the same mods. Your truck looks excellent from what I can see. I'd also like to see a full side view so I can see your lift/tire combo.
Thanks, if you have time it would be great.
Old 03-09-2017, 03:03 AM
That looks awesome. Just poke out a little, doesn't look like it would be to hard on paint without fender flares.
OEM wheel offset question smlford 6.0L Power Stroke Diesel 3 06-11-2016 12:08 PM
wheels offset vs backspacing Lgilliland 1999 to 2016 Super Duty 2 04-06-2015 03:32 PM
Want to offset wheels? dieseljock97 1999 to 2016 Super Duty 4 06-16-2013 05:53 PM
Best offset for aftermarket wheels. Fallguy2004 6.0L Power Stroke Diesel 3 12-19-2010 09:58 AM
Wheel offset/backspace ... swap ideas. Bob_91SC4x4 1961 - 1966 F-100 & Larger F-Series Trucks 1 08-07-2010 02:59 PM
Tags
1979, 2003, 2011, 20x10, 4x4, aerostar, f150, f250, fitamint, ford, fuel, lariat, offset, rim, truck, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
