2007 F350 Transmission Problems - Ford Truck Enthusiasts Forums
Old 12-31-2011, 01:45 AM
countryboy00001 countryboy00001 is offline
countryboy00001 is starting off with a positive reputation.
Major Help Please,
I have a 2007 Ford F350 4x4 Automatic with around 110,000 Miles. I have been having some transmission problems have tried several different things to fix it, however I keep coming up with the same problem. I keep getting different transmission codes. Here are the following codes that I keep getting.
P0751
P0756
P0761
P0766
What started all of this is the transmission not shifting down from 3<SUP itxtNodeId="695" itxtHarvested="0">rd</SUP> to 1<SUP itxtNodeId="694" itxtHarvested="0">st</SUP> when coasting for a ways to a stop. When I would start from a stop the transmission would take a little bit, then down shift. It then started to hesitate in shifting into forward from park. I then changed both filters and the fluid. Since this everything has went downhill. I then started getting a couple transmission codes. The first time I got any codes it was P0766 and P0761. I then got the ford book and tested all the solenoids and found all to be within par according to the ford book, however I did find the internal wiring harness to be out of specs. I cleaned everything up and put everything back together while I waited for the wiring harness to show up. The transmission was doing well for a couple of days then started acting up again. I also noticed that the shifting lever was hard to shift from Drive to Reverse. I pulled everything apart again and changed the wiring harness out. Everything again worked well for a couple of days then started up again. I have noticed that the shifting from Drive to Reverse is getting harder as things progress. I then pulled everything apart again and changed out the shifting rod. The transmission tested good for about 5 miles and now it is worse than it ever has been. Does anyone have any suggestions? Thanks
Old 12-31-2011, 09:38 AM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
What type of fluid and filters were used and are you running or ever run a tuner?
Old 12-31-2011, 11:50 AM
Mercon SP Transmission Fluid
Donít know what type of filters was on this truck prior to me changing them out. I put Wix filters back on internal and external at the time since this was the only thing that anyone had on hand. Since I have owned the truck, yes it does have a tuner and it is the Edge Evolution. I have only put about 15000 miles on this truck since I have owned it. What was done prior I do not know. I did pull the shifting linkage in the steering column yesterday and replaced it since the bushings were worn out. What happened next leads me to believe that it may be the PCM/TCM. After completing the repairs, started the truck and everything tested fine sitting in the driveway. Shut the truck off and went inside and cleaned up, come back out to take the truck for a test drive. Started the truck up and let everything warm up, put the truck into gear and you could hear the rpm change very little however the truck would not move. This is going forward and reverse. After playing around with the truck for a couple hours, everything started working again. During this process, I did get the Truck to show the Code P0751 twice. I have not taken the truck out for a test drive yet, since I donít know if it is going to leave me stranded.
Old 12-31-2011, 04:07 PM
cdev cdev is offline
cdev is starting off with a positive reputation.
some time back i had some issues with trans shifting the problem was a chafted wire from pcm to trans down below the engine lifting bracket on the frront of the engine this was on an e450
Old 12-31-2011, 04:52 PM
69cj's Avatar
Edge among some other tuners have been known to kill the torqueshift tranny.
Old 12-31-2011, 08:23 PM
2006lariat's Avatar
2006lariat 2006lariat is offline
2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation
Are you sure the shifter cable/linkage isn't bent/binded up somewhere? Hard shifting of the lever itself, would seem that somehow or another the cable got FUBARED. That may also be why it want's too stay in third, as it might be stuck inbetween 3rd and drive.
These are my guesses! Hell I dont even know if there is cables/linkages. For all I know the computer does everything.
Old 12-31-2011, 08:51 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
As far as I can see all those codes that you have posted come up as shift silinoids preformance/stuck
If you havent already get rid of the Edge tunner and pray you dont need a new tranny
SCT tunners are the only way to go for the 6.0
P0751
P0756
P0761
P0766
P0751 Shift Solenoid "A" Performance/Stuck Off G*
P0756 Shift Solenoid "B" Performance/Stuck Off
P0761 Shift Solenoid "C" Performance/Stuck Off
P0766 Shift Solenoid "D" Performance/Stuck Off
I dont know if you will just be able to replace all the shift silinoids or what
First thing that I would do is remove the edge tunner and see if that helps
then read thru this it may help your problem
http://www.ford-trucks.com/forums/84...eshooting.html
and this one too
http://www.ford-trucks.com/forums/81...-strategy.html
there were a couple more PDFs on tranney assembly/disassembly I couldnt find them in the tech folder so PM me your email if you want and I will send them to you
they were helpful and had pics of the shift silinoids and stuff
Definatly ccheck for shift lever Binding although dont know if it will help since the shift silinoid is electronic but couldnt hurt
Old 12-31-2011, 09:30 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03 SoCalSuperDuty03 is offline
SoCalSuperDuty03 is gaining momentum as a positive member of FTE.SoCalSuperDuty03 is gaining momentum as a positive member of FTE.
Quote:
I concur. I have seen it happen on several different occasions, including my own truck early in the 6.0 game. An Edge tuner was the first one I ever ran. When my 5R110 was dying, I had delayed reverse/delayed drive when shifting from park, no codes. Sampled the SP and it had high amounts of wear metals with only 20k on the truck. Sent the trans. to John Wood shortly thereafter. About this time people who were running Edge products to make HP began 'stacking' them with other programmers to control the transmission in an effort to keep the 5R110's alive.
Conversely, a friend had the same delayed reverse/drive symptoms, but it started kicking the solenoid codes like your truck. Again, sampled the fluid, and it contained wear metals (aluminum, iron, copper, lead) in amounts not normally found in trucks with fairly low mileage (about 50k). Shortly thereafter this truck went to John Wood as well. This truck also ran an Edge tuner.
I am not saying your trans. is dead, but it may be worth sampling the fluid to check for wear metal and soluble content.
Old 01-01-2012, 04:50 AM
I have removed the Edge programmer from the truck and am planning on taking a test drive tomorrow to see what may happen. I do know what was odd was the same day that I changed the filters and oil, the transmission went from have a little problem to doing nothing but falling on its face afterwards with major problems. I was also starting to lean towards the programmer being a problem since after I changed the shift cable with the truck being in stock mode, tested it in the drive way and the truck shifted fine. Then I reprogrammed the truck and then the truck would not move at all. I since then took it back to stock mode and after playing with it for a little bit, the truck started moving again. I also had someone tell me that low batteries maybe playing a part in this since they have been low. I had not put much thought into it since I was planning on taking care of this after I fixed the trans problem, but now I will take care of the batteries first then back to the transmission. Wish me luck and Thanks
Old 01-01-2012, 08:35 AM
69cj's Avatar
Low or bad batteries can take out your ficm and put undo strain on an already marginal alternator.
Old 12-05-2012, 07:12 AM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Quote:
Anybody know what the resolution was?
Old 12-05-2012, 11:26 AM
King-bRanch's Avatar
King-bRanch King-bRanch is offline
King-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant future
Quote:
yeah no kidding, posted all this then left us hanging 11 months...What gives
Old 12-05-2012, 01:40 PM
Sorry bout it takening so long to get back dont drive this truck that often. Thought i fixed it with a couple selonoid replacement however no fix just put in shop and found out torque converter and pump bad
Old 12-05-2012, 06:41 PM
f350ranchand f350ranchand is offline
f350ranchand is starting off with a positive reputation.
Mine was doin the same thing to it to my dealer had a whole grocery list of tranny codes left dealer ten miles down the road no gears at all now I'm puttin a low mileAge used tranny in
Old 12-05-2012, 08:15 PM
Prior to taking the truck to the ford house, I removed the transmission and completely disassembled it. I was surprise to only find to sets of clutches that were partially burnt and a couple of scuff marks on the pump pistons. I cleaned everything up and installed everything back together. After this I would find out upon the test drive that I also had a bad torque converter. By this time I was tired of messing with the truck so I took it over to the ford house. I was thinking that I had a torque converter problem or a solenoid problem, however was unable to do the pin point test without the ids. Upon testing the truck at the ford house they found that there were no electrical issues. So they pulled the transmission and found that the torque converter needed to be rebuilt, the pump had one stuck valves and two sticky valves along with the clutches that were partially burnt. I gave them the go ahead to rebuild the transmission. A new transmission pump, transmission rebuild kit and to rebuild my torque converter with the newer up to date parts was only $715.00 (Parts only). Have not picked the truck up yet from the ford house so I donít know yet what it is going to cost me there. The good part is that the company that I used to work for, I sent all the trucks over there for repairs so I hope they cut me a good deal.
Transmission No Shift into High dbradicich 1999 - 2003 7.3L Power Stroke Diesel 32 04-29-2014 07:21 AM
2004 F250 6.0 Rough Idle, Loses Power When Hot ten.mile 6.0L Power Stroke Diesel 3 12-12-2012 01:47 PM
Need a starting place for 6.0 Engine Issue ten.mile 1999 to 2016 Super Duty 2 12-11-2012 05:56 PM
2007 F350 Transmission Problems countryboy00001 1999 to 2016 Super Duty 6 01-01-2012 04:39 AM
1994 F350 Just got it with problems triggernut7788 1987 - 1996 F150 & Larger F-Series Trucks 36 10-12-2011 08:39 AM
Tags
05, 2007, 5r110, 60l, code, delayed, f250, f350, ford, hesitate, p0756, p0761, p0766, problems, reverse, shifting, shifts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
