Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > EcoBoost (3.5L, 2.0L)
Sign in using an external account
Register Forgot Password?
EcoBoost (3.5L, 2.0L) 3.5L Twin Turbo EcoBoost V6 and 2.0L I4 EcoBoost Engines
  #31 (permalink)
Old 01-25-2012, 09:55 AM
biz4two's Avatar
biz4two biz4two is offline
Garage is empty, add now
biz4two has a good reputation on FTE.biz4two has a good reputation on FTE.biz4two has a good reputation on FTE.
Arrow
^^^ x2 ^^^
Leave it on the side of the road...in neutral with emergency brake applied. That way the tow vehicle can winch it up. No need for key at that point...
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #32 (permalink)
Old 01-25-2012, 10:53 AM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
2009 Ford F-550
LSchicago2 has a very good reputation on FTE.LSchicago2 has a very good reputation on FTE.LSchicago2 has a very good reputation on FTE.
Quote:
Originally Posted by biz4two View Post
^^^ x2 ^^^
biz
Why would you want it towed without the key? Most dealer lots are difficult to drop a truck without a key, you can't steer it in a spot, or maneuver unless you have a perfect angle. How would the dealer work on it without the key? This makes no sense to me. The only way I'll tow a vehicle without the key is when keys are lost, and that will cost EXTRA for the extra labor and inconvenience. Most towing companies have similar policy's.
__________________
09 F550 Lariat S/C V10 4x4 tow truck, pics and specs at: http://www.cardomain.com/ride/3385538 2011 F550 XL V10 Rollback. Former trucks: 05 F450 S/C 6.0 F450 & 03 F450 V10 tow trucks. Facebook: http://www.facebook.com/profile.php?...81&ref=profile
My website: http://www.TowTruckLEDS.com
  #33 (permalink)
Old 01-25-2012, 03:51 PM
biz4two's Avatar
Arrow
Quote:
Valid points...but let me clarify.
I meant NO key in the ignition...so that it cannot be accidentally started before diagnostic tools can be connected. Trying to preserve any codes or evidence per se.
biz
__________________
  #34 (permalink)
Old 01-26-2012, 05:11 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a very good reputation on FTE.85lebaront2 has a very good reputation on FTE.85lebaront2 has a very good reputation on FTE.
william.a.vose
I guarantee they have something that will record real time data, I do, it's called a Snap-on Solus Pro. It will record a movie of the data you want that can be played back. You could try putting a big lightning rod on it so hopefully it'll get hit and fry all the electronics, then Ford would have to fix it. BTW, there is an emission performance warranty required by federal law, there is also a lemon law. Having worked a number of years ago in a dealership (not Ford) the policy then was if it runs, but not correctly, it is probably polluting, so it is a warranty issue, if it won't run at all, then it is not an emission warranty issue.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
  #35 (permalink)
Old 01-28-2012, 12:48 AM
New F150 Guy New F150 Guy is offline
New F150 Guy is starting off with a positive reputation.
So they called my wife and described that there was a corroded cable/wire and a "bolt" was loose. When I pick up the truck the paperwork doesn't show anything about the cable being corroded and I'm told they "cleaned it off". The bolt was a ground point, the same one the last dealership checked and said was tight and secure.
So I head down the highway and low and behold I'm getting 17.2 doing 70 mph. That is quite an improvement for not being able to duplicate or remedy the situation.
Then I start up a grade with the cruise on... Yep started that same "shudder" or whatever I should call it. The mileage went directly to 15.5 mpg. And there it stays just like all of the other times. I'm not sure if it is electrical, trans, engine, or computer related, but whatever causes that shudder causes something to trip and change the mpg of the truck.
I had about 80 miles on it with it averaging the 17+ and then the next 50 miles averaged 15.4. It is like someone flips a switch but I can't figure out what switch... (no the grade doesn't change to uphill and the wind doesn't change midway through the trip. I can drive this the opposite direction and get the same 15.5 average...)
Then the rough idle came back and all of the other symptoms have started to re-appear.
  #36 (permalink)
Old 02-02-2012, 01:38 AM
mustang_gt_350 mustang_gt_350 is offline
mustang_gt_350 is starting off with a positive reputation.
Anything new on the subject?
DO you have access to a video camera? or a digital cam that will take video with sound? If your drives are withing the recording limits of your camera. Every time you get in the truck turn the key on and the camera at the same time. Then you have proof that its something that can cause an accident and its not the drivers fault, and it will be already running so you can just pick it up and point it in the direction of the CEL and get a sweep of the gauges.
__________________
late 99 reg cab 4x4 4r100
www.DIY-injectors.com
Idm info (updated 3/17/08)
http://www.shol.com/shadow_tech/idmmod
  #37 (permalink)
Old 02-03-2012, 09:25 PM
Highboy74's Avatar
Highboy74 Highboy74 is offline
Highboy74 is starting off with a positive reputation.
Man this really sucks. It almost sounds like the main computer is bad. My dads 2003 150 4x4 with 193,000 miles on it displayed a lot of these symptoms you have described. The engine light came on and when we took it to Ford they declared it to be the computer.
I hate dealerships these days. If it wasn't for the fact my dad has bought 100's of Ford vehicles from the same dealership for the last 40 + years, I know he would get the run around as well. Matter of fact, I have a 2007 Mustang I have a posi going out in and the local dealership (not where my dad is located) gave me the run around yesterday and couldn't duplicate what I had described. They told me they drove it 40-50 miles and couldn't figure out what I was talking about. I went to pick up the Stang and they drove it 17.7 miles! So, today I went down there and told the service manager (very nicely) I wanted the rear end tech to ride with me. So, the tech jumps in the car I showed him the problem and of course, " Well, I cannot say for sure it's the rear end because it could be the clutch pressure plate." So, I told him (service manager and tech) about the 2 TSB's posted for the rear end posi clutch packs going bad. Got the run around on that too. I took my car in prior to the warranty expiring back in March of 2011 and they said it was the clutch. A year later clutch is still good and rear end feels as though it is gonna shake out from under the car. I took it to a differential guy I know in town and he verified it was in fact the rear end. The problem I have now is the car is 8,000 miles out of warranty. Either way, I will keep fighting the good fight. I could take it to my dad's dealer, but I don't want to drive 2 hours and not have the car for a week. I think its kind of fun listening the Ford dealership try and feed me bull*****.
To get back to your problem, I would ask the service manager to speak to the rep. Once you get ahold of the rep explain your issues, both with the truck and service department. Hopefully the rep will help you figure out the trucks problem. Also, look up the lemon law. I'm not too familiar with it, but I know people who have had vehicles replaced because the manufacture couldn't correct the problem.
Don't get discouraged with Ford either because my in-laws waist there money on Obama mobiles (Chebby) and they get the same flack at the Chebby dealer. No vehicle manufacture is going to give free parts and service away now more than ever.
If you know a good private vehicle repair shop on your town, have them look at it and see if they can find what is wrong with it. I used to work for one wrenching on cars and believe it or not more people than you think do this even when the vehicle is under warranty. We would tell them the issue and they would take it to the dealership and get it fix under warranty. Yeah, they spent less than a hundred bucks with us, but they got the issue taken care of.
This just my two cents. Please keep us updated.
  #38 (permalink)
Old 02-05-2012, 02:14 PM
Roasted7's Avatar
Roasted7 Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by New F150 Guy View Post
What do I have to do to get them to investigate the problem?
Not sure how the laws work in your state but in montana if you show up with the lemon law paperwork all filled out, they will lick you balls if that's what's required to fix the truck.
__________________
2003 F250 King Ranch PSD with lots of goodies.
www.hoginmachine.com
  #39 (permalink)
Old 02-07-2012, 06:37 PM
Powerdude Powerdude is offline
Powerdude is starting off with a positive reputation.
Wow, that really sucks. And to top it all off, you're in trouble with the old lady.
That's not good. I feel as though current manufacturer's use the customers to beta test their vehicle designs. All they do is run it through a computer simulation several times, enter it in a race, run it around a test track a few times, and Bingo !
Then they pronounce it ready for prime time.
It's really a shame. Turboed engines are just a tad more complicated than normally aspirate engines. You'd think they would have put in some way to store more parameters in the computer.
But then again, you'd be assuming that the design department actually had some authority. The final authority always lies with the stupid greedy bean counters.
  #40 (permalink)
Old 02-07-2012, 06:51 PM
biz4two's Avatar
Thumbs up
To the OP...
Might want to give this a try. It's called a Bluetooth OBDII Connector. Using it with a smartphone Android and an App called Torque...it will log data real time.
See link...
Bluetooth OBDII Connector - CravenSpeed Online
Good luck...
biz
__________________
  #41 (permalink)
Old 02-08-2012, 02:50 PM
kw5413's Avatar
kw5413 kw5413 is online now
Fortune Favors The Brave
2010 Lincoln MKT
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
Sounds like it is dumping fuel into the firebox.
Well, another trip to the dealership ought to do it for a cool glass of Lemonade. I you know what I mean?
If you do have to go the legal route some states require that the manufacturer buy the add-ons as well.
This story is starting to sound like the early 6.0 Diesel days...A nightmare Ford would probably still like to wake-up from.
Good luck..But, if it helps. My Eco is running great.
__________________
"You're doing a lot of choppin', but no chips are flyin'." - Foghorn Leghorn
"I am not afraid of death. It is the process of dying that bothers me."
Book of kw5413, Chapter 2012 Verse 05:17
  #42 (permalink)
Old 02-08-2012, 02:58 PM
kw5413's Avatar
2010 Lincoln MKT
Quote:
Update on mine i replaced the turbo solenoid myself $27.00 and 5 mins and i have not had the surging problem so far. I had the kam cleard and pcm reprogrammed be fore i did the replacement and that didnt work. I was also noticing the turbos dropping boost between shift points more often and now hardly at all.
http://www.ford-trucks.com/forums/11...g-problem.html
Sometimes descriptions are different but, the problem is the same.
May be nuthin' .....Good luck
__________________
  #43 (permalink)
Old 02-29-2012, 12:07 PM
countryboy69's Avatar
countryboy69 countryboy69 is offline
2011 Ford F-150
countryboy69 is starting off with a positive reputation.
there is a new tsb(not sure on the number) to reprogram the pcm and possible drivers side cat. it has enhanced misfire monitoring and some other updates. this may help it flag a code and help you get it fixed.
__________________
2011 fx4 crew 5.0l
  #44 (permalink)
Old 02-29-2012, 12:12 PM
2011 Ford F-150
the tsb number is 12-02-10
__________________
2011 fx4 crew 5.0l
  #45 (permalink)
Old 02-29-2012, 04:50 PM
I had the TSB applied to my truck. Didn't help. Seems as though it helped some for a short duration until it came back out of learning mode. Then things went back to the way they were prior to the TSB. Probably associated with coming out of learning mode again.
I had been slowly modding my truck, but my wife has put her foot down on any more mods until it is fixed or lemon lawed. I do appreciate all the info that guys post on forums like these, it is a great place to learn about the good and bad of specific models.
Tags
2012, 68, boost, coyote, eco, ecoboost, engine, f150, failure, failures, ford, problems, shaking, stall, truck, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
