Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 04-17-2003, 07:07 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
Post Spray in liner VS. Slide in liner
I have had a slide in liner before, and I liked it very much except for what it did to the paint in my bed. The problem I see with spray in liners, is that they would not be dent resistant, or scratch resistant. I used to slide axles and engines and all sorts of stuff on my slide in liner, I might get a few shavings off it, but nothing went through. I think If I was dropping loads of rocks on the spray on, it would dent the bed of the truck and scratch off the spray on coating. Has this happened to anyone?
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, DPS stage 1 injectors, GPR LED mod, Pyro/Boost guages-186whp 363wtq @ 10psi
1986 F-250HD XLT Lariat 4X4 6.9/T19, soup bowl mod, straight pipe.
  #2 (permalink)
Old 04-17-2003, 07:56 PM
Buckarcher's Avatar
Buckarcher Buckarcher is offline
Garage is empty, add now
Buckarcher is gaining momentum as a positive member of FTE.Buckarcher is gaining momentum as a positive member of FTE.
I have the Linex spray-on in my newer Super-Duty and a slide in liner in my 92. Yes it will dent, the little nicks and dings won't do it, but 200 lb oak log did a number on my tailgate, but my experience with the slide in liner in my other truck is that a force that large will dent through that one too. I have tried to scratch the liner and it holds up better than the slide in that I have in the older truck. I am seriously considering taking the plastic liner out, sandblasting/priming the bed and having it sprayed too. The truck isn't worth much though so I am not sure if it is worth it. Actually what I will likely do is wait until the wheel wells finish rusting through and then replace the bed and get that one sprayed.
__________________
JR
Quote:
Originally Posted by thorseshoeing
I've got a set of hand cuffs, ...and try as I might, I could not choke myself.
'Damn it, Otto, you're an alcoholic.' 'Damn it, Otto, you have lupus.' One of those two doesn't sound right.
  #3 (permalink)
Old 04-21-2003, 10:51 PM
theologian's Avatar
theologian theologian is offline
theologian is gaining momentum as a positive member of FTE.
I have a herculiner painted on liner in my old banger truck, (F150) and it does not get gouged out by all the junk I throw in there. I have a reflex liner sprayed into the '96 that seems very tough, much better than the plastic junk in the '02. I intend to change that one to a spray in one soon.
Theo
__________________
Theo
'95 Bronco
and a few other things - Mack truck, Iveco truck, Goldoni tractor...
  #4 (permalink)
Old 04-21-2003, 11:49 PM
Hi Ho's Avatar
Hi Ho Hi Ho is offline
Hi Ho is starting off with a positive reputation.
I don't have a bed liner in my 1977 F-250. Just a peice of plywood. I really beat it up too. Rocks, jagged metal, tools, dirt, just about anything. The paint is really tough and I don't have any rust in the bed.
  #5 (permalink)
Old 04-24-2003, 01:06 AM
damonlan damonlan is offline
damonlan is starting off with a positive reputation.
Look here.
http://www.ford-trucks.com/forums/sh...threadid=98710
My response in that thread is kind of winded but informative. If you want to keep your truck pretty, I'll understand.
__________________
Damon
KC5AOS
  #6 (permalink)
Old 04-26-2003, 01:49 PM
Karic's Avatar
Karic Karic is offline
Karic is starting off with a positive reputation.
I really don't care for the plastic "liners" due to the condensation build up underneath. I've seen some ugly results.
I thought a rubber mat would generate the same problems, so I used plywood for years. Then I found this:
Click the image to open in full size.
It's a piece of rubber floor matting. I scored this chunk from the Air Force guys here at the airport. This really works well, the ventilation holes allow everything the dry out and it's easy to remove to clean under it.
Unfortunately no one could tell me where to buy it, but any large industrial supply outlet should have the snap-together stuff and it would work just as well. The similar stuff we use in our fire truck compartments is about $10CDN per square foot piece, snaps together and is easily cut with a utility knife.
Just another idea,
Rick
__________________
http://www.ford-trucks.com/user_gall...oid=13199&.jpg'03 F350 SD Supercab XLT 2wd Dually, Long box, V10, Auto, 3.73, Toreador Red, Medium Flint.
  #7 (permalink)
Old 04-27-2003, 01:22 AM
-karic-
No that is a cool liner. A+ for the grab. Even I would be tempted if I could score one of those.
__________________
Damon
KC5AOS
  #8 (permalink)
Old 05-05-2003, 11:06 PM
Bikeitswift Bikeitswift is offline
Bikeitswift is starting off with a positive reputation.
Lightbulb Spray in liner VS. Slide in liner
My 63 F100 is nice, but the bed is horribly lumped up. The spray liner the prvious owner put in couldn't hide those lumps. Now (look at my gallery) I've put in a piece of 3/4" Pressure Treated Plywood, and bolted some $5.00 swap meet strips(guess that's what Chevy parts are worth), add new carriage bolts and washers, an angle iron "lip" at the tail end...Whalaa!! About $30.00, looks great, and could always be repaired (the plywood was $21.00) cheaply. I'm gonna make "filler" pieces for the area in front and rear of the wheel wells. I'd put the picture here, but I don't know how. I've had more than a few fellow truckers kick themselves for spending $400.00 more. Not show grade, but very nice in a driver.
__________________
At the Lake
Tags
bed, liner, slide, spray
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
