Possible C6 to AOD Transmission Swap? - Ford Truck Enthusiasts Forums
Old 12-30-2011, 09:40 PM
Halloran1's Avatar
Halloran1 Halloran1 is offline
Halloran1 is starting off with a positive reputation.
I have a 1992 F250 HD 4x4 with the 460, hooked up to the C6. I would like to swap out the C6. My dad suggested to swap it out for the E4OD, but when I read up on it, looks like it gets real expensive real quick. After a little more research, I came across the EOD transmission.
Questions:
Is it possible to do this swap?
And if so, would I need something like an adapter kit because of bolt pattern, or any other complications? Or is it a strait, bolt in swap?
Thanks, anything helps.
Jake
Old 12-30-2011, 09:52 PM
redrivergorge's Avatar
redrivergorge redrivergorge is offline
redrivergorge is starting off with a positive reputation.
You would need a bell housing adapter. Theres 3 bell housings small block, big block and diesel. They didn't put an aod behind the 460 because its not strong enough for it.
Old 12-31-2011, 02:24 AM
Halloran1's Avatar
I'm sorry, I meant AOD, not EOD. Thank you for the info, though.. Would you happen to know anything about the AOD-E? I read some stuff about that too, but didn't quite understand what they were saying.
Old 12-31-2011, 11:24 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
The AODE was a computer controlled 4 speed auto that Ford used in some cars. The truck version was the 4R70W, however, as rrg said about the AOD, it was never produced with the big block bellhousing.
Old 12-31-2011, 11:33 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The AOD isn't an option for a big block truck, even if it would attach to the engine it would have to be builtup with aftermarket parts to handle the torque loads put on it by that motor and the heavy vehicle. The E4OD is the only automatic overdrive trans option for you but it requires wiring additions and a computer swap, a ZF 5-speed manual would give you OD without any wiring or computer changes.
Old 12-31-2011, 01:44 PM
Halloran1's Avatar
I see... thank you all. So looks like that's out. I guess I'll go for the E4OD then.
Old 12-31-2011, 05:51 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
That's going to be a complicated swap, especially if you don't like messing with wires. You will have to get a ecu from a 460/e4od combo and make up your own harness for the trans to the ecu. Or get a separate stand alone system at $1000+
ZF 5 speed would be easier. All you would need is the trans, clutch, master cylinder, pedal assembly, driveshafts and crossmembers.
Old 12-31-2011, 09:29 PM
Halloran1's Avatar
I've read up on the ZF 5, but the thought of turning my truck into a stick shift is all bad for me... I mean I know that there's a lot of advantages and such, but I'd rather just keep it an automatic. So... E4OD. That's what I'm thinkin.
Coyote or 6.2 with manual transmission Kyler7700 Clutch, Transmission, Differential, Axle & Transfer Case 3 12-26-2015 09:41 PM
351m to 460 swap F100 2wd sleddogg Engine Swaps 1 10-01-2014 01:49 AM
WTB 351m/400 manual transmission block plate joerickson WTB - Parts & other 2 12-09-2013 10:08 PM
zf 542 trans swap 1979 f250 794Dman 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-14-2012 03:09 PM
E100 Automatic Transmission Swap cornfed937 1961 - 1966 F-100 & Larger F-Series Trucks 6 10-26-2005 07:46 AM
Tags
460, adapter, aod, c6, cford, conversion, expeditioneconoline, f2, f350, ford, kit, swap, swapping, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
