bed swap - Ford Truck Enthusiasts Forums
bed swap
Old 12-30-2011, 08:47 PM
boa1558 boa1558 is offline
boa1558 is starting off with a positive reputation.
bed swap
will the bed from a 1984 F250 fit on a 1991 F250 if so will the body lines match up? I know the tailights and tailgate are different but I can live with that
Old 12-30-2011, 11:01 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Not real sure about the mounts on the btm, I imagine that you would have to make adjustments at the frame. It appears that the top rail lengths are the same.
Maybe someone else has some more info.
Old 12-31-2011, 12:04 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
The wheel arches are diff. The 80-86 are more squared it'll fit, just look different.
Old 12-31-2011, 12:40 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
yeah all the mounts are the same IIRC.
Old 12-31-2011, 10:39 AM
Bed swap
Thanks for all your help, wow are the wheel well opening different, thought I had look at all of it but man was I wrong
Old 12-31-2011, 10:44 AM
Edgethis's Avatar
You could swap the front clip over too. Then you'd have the sweet flat nose instead of the 87-91. I think it'd be sweet
1979 f250 bed ty.Harris 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-05-2015 04:02 AM
Bed fitting. jerryparks 1987 - 1996 F150 & Larger F-Series Trucks 4 06-16-2014 07:44 PM
Bed swap? 61fordf25 1961 - 1966 F-100 & Larger F-Series Trucks 2 12-15-2010 02:06 PM
Maximum weight in bed. sixty9cougar 6.0L Power Stroke Diesel 11 11-26-2010 07:41 PM
68 100 bed on a 75 250? dead_eye 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-05-2003 01:37 AM
Tags
1960, 1984, 1991, 91, bed, f100, f150, f250, ford, interchange, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
