Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-30-2011, 12:41 PM
thefnswits thefnswits is offline
Garage is empty, add now
thefnswits is starting off with a positive reputation.
k&n filter vibration?
Alright s I just instaled the k&n air intake ad it sounsmean except I get a wicked dash rattle frm acoustic vibrations around 3200 rpm to 3500. Any ideas?
  #2 (permalink)
Old 12-31-2011, 12:25 AM
Tylus's Avatar
Tylus Tylus is online now
Nuke Mechanic
2006 Ford F-250
Tylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant futureTylus has a brilliant future
normal
that intake is worthless btw. I'd remove and return it for your $$$ back. Then take the $$$ and buy a SCT tuner and get custom tunes.
You'll get better performance and no annoying buzz or harmonics at certain rpm's
__________________
United States Navy - Bubblehead
2002 Excursion XLT w/ V-10 <-- The new toy
2012 Flex Limited <-- 17 mpg city, 27 mpg highway
  #3 (permalink)
Old 12-31-2011, 07:23 AM
I know you and mcdavis are intake haters...any reason why? I highly doubt anyone has ever put their expo on a dyno.
And I keep reading abou you guys saying "custom tune", what's so custom about it? I am interested in the tuner, just want more details. Thanks an happy new years!
  #4 (permalink)
Old 12-31-2011, 11:17 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
I'm not a CAI hater. I ran one on my 06 F-150 (Volant). It made great noises, but nothing performance wise. I finally strapped a blower on there for real giddy-up
I ran one on my 09 Mustang Bullitt...now that was good for +15 HP with factory tune...and over 30 RWHP paired with long tubes and full offroad exhaust.
You are only going to see 3-5 HP on a good day from a CAI on a 6,000 lbs vehicle. Tuning might get you closer to 10 HP gain.
As far as tuning, most of the "Custom" tunes you buy are canned. The tuner takes a know profile that makes good power, tweaks it to your octane and location and sends it to you. I've had great success with those using my Mustang because a dyno wasn't available where I live
Once you have the tune installed, you can data log. Send that back to the tuner and they can tweak things in to give you a truly custom tune
__________________
  #5 (permalink)
Old 12-31-2011, 11:46 AM
It was only 215 bucks and it sounds like a beast. I'm hapyy with that. Any advice on a exhaust or an aftermarket MAF? Who should I talk to at sct? Finally, can I get a tune for 87 octane? I don't really need to spend more on gas...thanks!
  #6 (permalink)
Old 12-31-2011, 05:56 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
It's only about $5 more per tank to run 91-93 octane vice 87 octane. That's a pack of cigarettes or a Starbucks.
You can get a 87 octane tune. Pointless in my eyes as its essentially a transmission only tune. You're going to spend $300-$400 on a tuner and tuning, what's another $5 each tankfull?
__________________
  #7 (permalink)
Old 01-02-2012, 03:31 AM
f150dave2002 f150dave2002 is offline
f150dave2002 is starting off with a positive reputation.
Its probably where the intake comes in through the "cold air" shield. Mine rattled there. The fix I made was to get some black fuel line hose and split it length wise and put it around the opening where the plastic air line connects to the filter. If this isn't it, make sure all your radiator clamps are tight. Drive for a while and then check for shiny spots where something is vibrating against. Or with the engine running and the hood open, pull your throttle cable and see if you can pin point the rattle.
Hope this helps, PM me or I'll check back if this works for you. Otherwise my late night coffee induced rambling should get a picture to help say what my words may be missing.
  #8 (permalink)
Old 01-02-2012, 08:39 AM
thanks for the info. the rattle in mine seems to come from the dash, inside the cab. it only does it under full throttle. rest of the time it sounds good.
__________________
1999 F250 5.4 Lariat 4x4 Off-road 8' Boss steel plow
2008 Expedition Limited everything except 3.73's and air suspension!
2007 Mitsu Fuso FG4x4 dump 9.2 Boss Vplow, 2.5 yd torwel sander
  #9 (permalink)
Old 01-02-2012, 10:39 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Is the rest of your truck stock? Exhaust? The funky shape of the OEM intake is because it stops odd harmonics similar to what you are hearing. The K and N is more than likely creating resonance and that is vibrating the dash plastic. The dash is known for rattles, etc. If you can recreate the rattle without blowing up your engine while parked you might be able to locate it and then add foam/felt tape/etc. to eliminate it.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
08, 2001, bullitt, dash, expedition, filter, ford, fordexpedition, intake, kn, knn, rattle, vibrating, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
