Air Conditioner install advice needed
I went to the local hot rod shop wednesday and borrowed their mock up case for a vintage air gen II ac unit. The unit itself will fit under the dash, but I'm having trouble with where the lines will run. I've got the battery in the stock location, pass side, right in front of the firewall so I can't run the lines there. My other choices are to raise the unit up, and run the lines underneath. Or lower the unit, and run the line above. Any one done this yet, or do I get to be the first?
Hey Rusty,
I feel your pain - We've got a 1950 F1 - In Texas A/C isn't really an optional item so we looked hard at all alternatives. We wanted everything hidden & beautiful but after looking under the dash there just was no hope of that in our's. We went with Vintage Air's Under Dash Mount system - the "Mini Slimline variation". It's not the prettiest but it has heat, a/c & defrost & works like a champ. Function over beauty on this one - had to have A/C. (It's not as big as the picture shows - plenty of room for legs).
The battery is behind the seat to free up space in the engine bay, (our gas tank is back under the bed).
Ben in Austin
Ben in Austin
Here are two of mine coming from the compressor and through the firewall (it seems to be the most inconspicuous way). The other two are run similar to 49willard's, but they go up to the condensor/accumulator that are located behind the grill.
lineman113
03-13-2012 02:38 AM
theGman
15
04-12-2005 04:55 PM
terry02
07-24-2003 09:57 AM
1966, 1979, air, article, block, cleaning, conditioner, conditioning, conditions, dashboard, f100, ford, installing, powered, vintage
