Fuel / water leak
Old 12-30-2011, 07:57 AM
E-Mo's Avatar
E-Mo
E-Mo is offline
Fuel / water leak
Hello all,
so I noticed the other day that the truck smelled extra gassy, I opened the hood and revved the truck a little and saw what looks like a mixture of gas, water and maybe air squirting out of a small hole here. <a href="http://imgur.com/ixGR6"><img src="https://i.imgur.com/ixGR6.jpg" alt="" title="Hosted by imgur.com" /></a>
Is this the fuel pump? and is there supposed to be a small screw size hole open on the back of it?
thanks,
E
Old 12-30-2011, 08:13 AM
huckdeuceman's Avatar
huckdeuceman
huckdeuceman is offline
Yes'' that is your fuel pump!!..it's bad!!!!..replace...PS, that's not water! that's gasoline' so don't drive it that way...
Old 12-30-2011, 08:37 AM
spurredon's Avatar
spurredon
spurredon is offline
DITTO! DITTO! You could go up in flames!
Old 12-30-2011, 08:40 AM
E-Mo's Avatar
E-Mo
E-Mo is offline
Thanks, it didn't smell like straight gas that's why I thought maybe there was some moisture/water in it.
Carb is still getting fuel, so can I just plug the hole where it's leaking?
Pump looks original though and I'm not sure when, if ever the fuel filter has been replaced.
If I have to get a new one, is it something local auto stores have or is it better to get a certain kind of fuel pump from an online store?
thanks again.
Old 12-30-2011, 08:48 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Don't plug the hole! Replace pump. Next thing to happen, is diaphram will start leaking into crankcase and you will have serious issues.
Old 12-30-2011, 09:37 AM
Marky48170's Avatar
Marky48170
Marky48170 is offline
65 f250, 67 f100, 76 f250
One of 2 things will happen either the engine will seize or BOOM !!!!
Old 12-30-2011, 04:24 PM
bunchoftrucks's Avatar
bunchoftrucks
bunchoftrucks is offline
Either replace it or wait and drive it until it makes really expensive noises like KABOOM and CRACKLE CRACKLE as the flames gobble your truck up. Yes those pumps are available at Auto Zone , Advanced, NAPA, O'rielly's etc. That hole is like the ones on your water pump, kinda like a tattle tale it lets you know it's going away and needs to be replaced.
Old 12-30-2011, 05:19 PM
OldHarley's Avatar
OldHarley
OldHarley is offline
In a new fuel pump, a rubber diaphragm works off the camshaft to pump gasoline. That hole in the fuel pump is open to the atmosphere and allows the air pressure to equalize when the diaphragm moves so you can't just plug it.
When the rubber diaphragm goes bye-bye and begins leaking, then gasoline, rather than air, will come out of that hole.
It will progressively get worse and as noted above, is very dangerous.
Old 12-31-2011, 01:08 AM
garbz2's Avatar
garbz2
garbz2 is offline
Gasoline will also thin the oil as it leaks in to the crankcase. Spun bearings are the result when the oil thins to much due to not repairing the pump.
Garbz
Old 12-31-2011, 08:10 AM
E-Mo's Avatar
E-Mo
E-Mo is offline
thanks for the explanation, it helps me understand how the pump works now. I'll replace it, looks like it's only $33 at AutoZone. Hopefully it hasn't done any permanent damage by leaking gas into crank.
kabur66
6.7L Power Stroke Diesel
10-28-2011 04:11 PM
timcos
02-27-2009 02:55 PM
65f100_352
Alternative Fuels, Hybrids & Mileage
07-18-2007 07:07 AM
glangwell
09-05-2003 01:39 AM
Quick Reply: Fuel / water leak
