351m to 400m Conversion - Ford Truck Enthusiasts Forums
Old 12-30-2011, 12:34 AM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
Well it's time to start thinking about the engine. It will be going in a city driving truck so it doesn't need to be outrageous. I have a stock 351m that I want to make into a 400. I'm not sure how to go about this. I know I will need a new crankshaft. Do I need to get new pistons and connecting rods? It will hopefully be getting a edelbrock power package when I'm done unless you have a better idea. Want to try to use the heads I have but if I need to I can get new ones. Want to get rid of the emissions crap and only keep the vacuum lines that are necessary for running.
Here's my idea's.
Edelbrock 2171PK Edelbrock Performer Power Packages
Edelbrock 61629 Edelbrock Ford 351C/351M/400M Performer RPM Heads
I'm sure I missed something but ask and you shall receive.
Old 12-30-2011, 12:56 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Old 12-30-2011, 01:45 AM
JB78f150's Avatar
Ya just thought I might try both places.
Old 12-30-2011, 11:39 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
All you need is the crank & pistons.
Old 12-30-2011, 01:51 PM
JB78f150's Avatar
Anyone know a good cam for it if I get the 9.3 CR full balance assembly from TMI?
Old 12-30-2011, 05:36 PM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
I really like roller cams for these engines. 9.3 is pushin it for stock heads. Preignition problems. I use the Snowperformance water injection setup on mine. Works great and only when the engine needs it.
Old 12-30-2011, 06:02 PM
JB78f150's Avatar
Tmeyers says its for use with stock heads.
Old 12-31-2011, 11:25 AM
POPAJON POPAJON is offline
POPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud of
Listen to Tim. He IS the guru for the 400s. Tim will also recommend a cam and lifters for you to. In fact just tell him what you want and he will set you up. He's a great guy to deal with and doesn't lead you astray. Popa John
Old 12-31-2011, 10:51 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Summit's P/N 5200 cam works great in a 400.
adding edelbrock 2171PK to my stock 351M. Anyone else running this setup? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-22-2016 11:21 AM
EGR vs NON-EGR Intakes MyName1sMud 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-06-2013 07:24 PM
351m to 400m Conversion JB78f150 1973 - 1979 F-100 & Larger F-Series Trucks 10 12-30-2011 01:49 AM
Edelbrock 2092 Power Package markthompson999 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 01-17-2011 09:11 PM
Edelbrock carb install questions.... dsrtjeeper 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-04-2011 05:15 PM
Tags
351m, 400, 400m, conversion, conversions, edelbrock, kit, motor, nj, package, performer, power, powered, rpm, shops, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
