AirLift Wireless air will not deflate
I had this problem for awhile. When inflating my wireless system then deflate the bags after towing, only one side will let out air. I have already exchanged the manifold with Airlift once because of this problem with the left side bag. Now the right side bag has the problem. I have double checked my settings on the remote to make sure I was deflating both bags. The only way I can get the air out now is to pull the line out of the manifold. I don't want another crappy manifold if the same problem happens again.... Has this happened to anybody else?
ohh boy im on my 3rd manifold ,,,i have used air lift before in my tundra bo problem for 3 yrs .. but ever since i put these in the ford one headache after another same problem with deflating but mine was always on the right side anyway they thought it was the air bag anti-freeze but it wasn't any way possible water or condensation buidup ,,, even the smallest of dirt particle can jam up; manifold ,,, Solution was (yes i know i should'nt of had to spend money on this but to not have to be down for anytime here is what i did 3 inline push on air filters theay are small and $6 each , i put one one the incoming air side , and 1on each output
/input side and no more problems ,,,,
on
Mine hasn't given me that problem. The bags do inflate and deflate at different rates sometimes lagging behind the other by as much as 15 lbs but they always end up at the same pressure. I once inflated to 100 lbs and had a hard time getting them to deflate at all. I just messed with several different keystroke combinations on the wireless controller and it eventually worked. Other than that, all okay.
How long ago did you by the unit, and do you remember when it was that you exchanged the manifolds?
Thanks for brining this issue to our attention. The next item on my list of things to buy is an airbag setup. I am looking at the AirLift 5000's and the wireless compressor setup. I am about a month away from buying and interested to see how customer service handles your issues and whether there is something inherently wrong with the overall design - given that you have already replaced the manifold several times and still having the same issue.
I will forward your information onto our customer service area. I will follow up with them this afternoon and see what they suggest. Hopefully will have a response for you today.
FYI that this thing rides all messed up with one side 5psi, and the other at 60psi. Thank Lord I can reach under the fender and pull the air line.
I talked with our lead engineer, and they have seen this situation with some previous batches of manifolds. He explained that it is caused by a large pressure differential between the two bags.
I apologize for the delay with customer service you had today, I know there are a couple of people on vacation today due to the holiday. The recommendation I received was to have you swap it out again. They have addressed this issue on the newer manifolds, I'm not positive when the newer manifolds were released, this may have happened since October.
I will contact customer service as well as our Marketing Director on Tuesday when everyone returns to the office.
Again, I apologize for the problems you are having, and I will do everything I can to make sure you end up happy in the end.
I believe what he was implying is that prior to trying to deflate the bags there was already an unequal pressure in the bags.
Those with similar issues, did you have equal pressure in each bag prior to deflating or were they aired up at different pressures? Either way is the proper use of the system, I'm just trying to determine if there are other issues leading to the problem.
I talked with a couple of people in house this morning, and if you can we would like for you to call one of sales team direct. He can get your contact information and get a replacement manifold out as soon as possible.
I PM'd his contact information to you, he was copied on some of the communication so he should be aware of what problems you are having. Please let me know if you don't get the service you hope to.
I had/have the same problem. Been kind of frustrated with it.
One side was not deflating fast enough it seemed, and then with repeated attempts to either inflate or deflate all I ended up with was one bag empty and one bag at 100 psi.
Manifold was changed out as well as all the wiring and relay. Though was that maybe the diode in the harness was also an issue.
Now I have 2 manifolds, one will not match to the controller no matter what I do and the other will only see "one side" of the manifold.
Just last night I put the manifolds, relays and harness' in a box to do something with. Don't need it now as the tow season is over.
My problem started just before warranty was up (parts sent) and I never got it working right and no warranty now.
Was really hoping to be able to use a second manifold to run the air bag in my hitch as well as air bag for the truck.
