Thanks,its been a long road....power wise should be between 450/500..if not i will be sick...
I'm sure you will hit those HP numbers with the right tuning.
My power adders are 38R, 200/80 Casserly singles,at the time an Adrenaline and Jody's live tuning.
450+ RWHP at RRW in 2010. And that was with muffler and AIS.
That sounds promising....After I get a few miles on her and live tuned agean..I am going to dino it and will post up what the numbers are
At RRE 2010 my truck had over 106K miles and from the heads down was all stock. Still has the fuel bowl. Only fuel system mods at that time were a CCK, Walbro fuel pump and shimmed FPR spring. I think 450+ will be there for you. The only question is how far above 450.
as for now, i am retaining the stock fuel system,i have done the CCK and using using Clays FRX,stock pump holds at 69psi and 59-60wot so it will be interesting to see with this motor..I was speaking with Full Force in regards to the injectors and they got me to order the walbro fuel pump...I am planing to see what the stock pump will do before i install it....
Fuel modifactions to come after my wallet recovers from the build....
