TPS problems2002 F-350 7.3 - Ford Truck Enthusiasts Forums
Old 12-29-2011, 11:05 AM
Billygen Billygen is offline
Billygen is starting off with a positive reputation.
Angry TPS problems2002 F-350 7.3
Been having issues with pedal quit responding,scan showed PO123 so I got new pedal assem from ford and it worked fine for a few days and now its back like it was maybe worse, the engine light comes on when it dosent respond and goes out when it picks back up. where to next?
Old 12-29-2011, 01:44 PM
Or does anybody have a wiring schematic of pedal assembly?
Old 12-29-2011, 03:39 PM
TXtinct's Avatar
TXtinct TXtinct is offline
You'll shoot your eye out
TXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputation
TPS reports
Old 12-29-2011, 06:09 PM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
Welcome and tell us more about your truck. All stock or...
Any problems with gauges or fuses when this happens?
This thread sounds similar to your issue, and has some TSB info.
http://www.ford-trucks.com/forums/69...-problems.html
Good luck, and a Bump
Old 12-30-2011, 08:40 AM
Truck is all stock, 7.3, 6 speed, duelly, and no problems with any gauges or fuses. My cruise doesnt work when I push on and coast at the same time the horn will sound, but other than that all else is good. I will go through this thread today and see what comes up, thanks for the info!
Throttle response acting funny Shu 1999 - 2003 7.3L Power Stroke Diesel 4 12-17-2015 04:49 PM
Engine shutting done with diagnostics whits 1999 - 2003 7.3L Power Stroke Diesel 4 11-06-2014 01:17 AM
Turbo sticking or pedal sensor? Rod Jr. 6.0L Power Stroke Diesel 17 10-04-2014 09:43 AM
96 F-350 7.3 losing power and won't respond to pedal MJ2525 1994.5 - 1997 7.3L Power Stroke Diesel 30 08-29-2013 06:54 PM
Intermittent Accelerator pedal tankd72 6.0L Power Stroke Diesel 8 10-02-2011 10:26 PM
Tags
2002, 2003, 350, 73, 73l, 99, buy, changing, diesle, excursion, f350, ford, fuse, position, postion, sensor, throttle, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
