Slow and loud at half throttle
Old 12-29-2011, 09:29 PM
johnarahill's Avatar
johnarahill
johnarahill is offline
My truck has been slow as hell lately, and it's loud as all get-out at half throttle. It seems like I can get alot of increased rpms without alot of increased speed (until the boost kicks in). At part throttle its loud and has a clanky knocking sound to it that wasn't there before (doesn't sound like an exhaust leak though). I recently replaced the HPOP, ICP, and rebuilt the fuel bowl. This was happening before I did all of that. Not pulling any unusual codes with the Superchips Cortex. Already tried pulling and plugging the wastegate line, no change. Recently did the fifty cent mod, all injectors are reading less than 5 ohms. Oil in HPOP res is right. Also cleaned out the EBPV tube last week, no change. I've got AE software on the way from Clay. Does anyone have any suggestions?
Old 12-29-2011, 09:32 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Have you checked fuel pressure?
Old 12-29-2011, 09:42 PM
johnarahill
Nope. Not quite sure the best way to do it....but I did do the hutch mod and the harpoon mod. Truck didn't change. What's the best way to check the fuel pressure?
Old 12-29-2011, 09:46 PM
BigAlsPSD's Avatar
BigAlsPSD
Gauge hooked to the fuel bowl is the best way so that you can observe it while driving. If you have done the in tanks mods odds are your delivery is ok, but you might have a regulator issue or clogged pump screen.
Old 12-29-2011, 09:48 PM
johnarahill
Maybe it's a pump screen. Don't think it's FPR, as i also put the FRX mod on and replaced the spring and cleaned the poppet valve. Is there a way to check the pump screen?
Old 12-29-2011, 09:54 PM
BigAlsPSD's Avatar
BigAlsPSD
Fuel pressure was just a thought, guess with the mods you have done, it really shouldn't be too much of an issue. Easiest way to check for restriction would be with gauge, but you could remove it and visually inspect, although it's not likely the issue.
Old 12-29-2011, 10:03 PM
johnarahill
I was still buyin it though. Might still be buyin it.
Old 12-29-2011, 10:57 PM
BigAlsPSD's Avatar
BigAlsPSD
Have retorqued your injector hold downs or rockers in a while? They can make some rackit too when they loosen up.
Old 12-29-2011, 11:07 PM
johnarahill
Did all that a few weeks ago when I did the 50 cent mod...
Old 12-29-2011, 11:14 PM
BigAlsPSD's Avatar
BigAlsPSD
Leaking up-pipes or manifolds? Really just throwing things out now, since it seems like you have been through it pretty well.
You say at 1/2 throttle so, up to half throttle is it responsive? Slow at half throttle would be relative to what RPM's were, at 1/2 throttle is it still accelerating? I actually would guess that I rarely go over half throttle...
Old 12-30-2011, 08:18 AM
johnarahill
I guess not really half throttle, part throttle, or accelerating slowly...
Old 12-30-2011, 09:13 AM
johnarahill
Could I potentially be looking at a torque converter issue?
TKegs763
08-17-2013 09:23 AM
62uni4x4
03-18-2011 02:19 PM
cowmilker08
12-12-2008 01:02 PM
DG65
15
07-08-2008 11:37 PM
nuclearmonster
04-04-2004 12:48 AM
Quick Reply: Slow and loud at half throttle
