Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-28-2011, 10:31 PM
MARC's Avatar
MARC MARC is offline
1959 Ford F-100
MARC is starting off with a positive reputation.
Looking for heater core
For 59 f100. Any ideas. None at obsolete or sac vintage ford
Thx Marc
  #2 (permalink)
Old 12-29-2011, 06:42 AM
spurredon's Avatar
spurredon spurredon is offline
Garage is empty, add now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I don't think you will find one out there that is just plug and play. If money is no object, you can find a core that is close to the same size and reuse the tanks. I ended up getting one for a newer truck and had to get a little creative with heater hose. I can't remember with year is close but I will try to find my notes and get back to you. I spent a couple weeks off and on trying to find one. I got one that had short straight tubes coming off the tank, used short pieces of heater hose to connect to to original tubes from the original tank that I cut off to stick thru the firewall. It looks great under the hood, you can't see a difference. You can only see the change if you lay on the floor of the truck and look up between the heater and the firewall. It is very functional.
  #3 (permalink)
Old 12-29-2011, 10:50 AM
Tomget's Avatar
Tomget Tomget is offline
Tomget is starting off with a positive reputation.
This kinda stuff appears on ebay from time to time.
__________________
Tom
1948 F-1 312Y,oem4spd,Holley 2150,Merc diff
Other projects: 48IH chopped&channeled,58F100 460 C6 4link pro street
  #4 (permalink)
Old 12-29-2011, 03:04 PM
57icebox 57icebox is offline
57icebox is starting off with a positive reputation.
Here are a couple if threads with some info about heater cores.
http://www.ford-trucks.com/forums/10...ater-core.html
http://www.ford-trucks.com/forums/70...r-57-60-a.html
  #5 (permalink)
Old 12-31-2011, 05:40 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
B7TT-18476-A (replaced B7C-18476-B & B7C-18476-C) .. Heater Core / Obsolete
Applications: 1957/60 F100/700 / No Ford Dealer or obsolete parts vendor has any.
Any radiator shop can recore a heater core.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #6 (permalink)
Old 01-01-2012, 01:25 PM
bruman bruman is offline
bruman is starting off with a positive reputation.
Making an heater core!
Hi!
I,m new to this site and very excited about finding it.
I have an idea about making a heater core by using PEX tubing & coiling it up inside the heater box, similar to the concept of burying tubing in concrete slabs in new houses & running hot water thru it, & tying it into my heater hoses W/ a throttling valve to control the temp.
It would be really inexpensive to make & it would reaaly be nice to have heat again!!
What do you'all think?
Bruman
1960 F-100
'86 302 w/ AOD
self contained electronic dist.
mild cam
3.0 gears
& hopefully a crown vic suspension soon!
  #7 (permalink)
Old 01-01-2012, 09:25 PM
Bill W's Avatar
Bill W Bill W is offline
AZ Chapter Ldr
1963 Ford F-250
My Garage
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
Bill Wilson
try performance radiator on Ft lowell Marc. they did a great job on mine.
__________________
Join the Arizona Chapter Here!
  #8 (permalink)
Old 01-01-2012, 10:02 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is online now
theodore/teddy is starting off with a positive reputation.
Marc; Do you have your old core if you do they really are not that hard to repair (torch solder and flux) unless it froze and split multiple rows in the core, if the tank is cracked that can be soldered as well. You can us a bicycle tube to pressure test it. Any radiator shop can re-core it!
Good luck
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #9 (permalink)
Old 01-05-2012, 12:12 AM
MARC's Avatar
1959 Ford F-100
Bill, what did they charge to rebuild the core?
  #10 (permalink)
Old 01-05-2012, 04:54 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
Hello there,
The PEX tubing does not have the heat transfer capability of the standard heater core. At best you will warm the air a little bit, but not enough to get comfortable. Your best bet is to find a good used core or a repairable one. A heater core has a large surface area for both the coolant and the air that you would need well over a hundred feet of PEX tubing to replicate.
Quote:
Originally Posted by bruman View Post
Hi!
Bruman
1960 F-100
'86 302 w/ AOD
mild cam
3.0 gears
  #11 (permalink)
Old 02-11-2012, 03:05 PM
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
I've found a heater core today that is almost a direct fit. Murray's/O'Reilly auto parts
Part # 39801. Its aluminum, not brass. $22.95 plus tax.
They let me search their radiator book that was on the shelf. They had the core there too.
  #12 (permalink)
Old 02-11-2012, 03:51 PM
Hey Hoss, I can't thank you enough!!! This is great news. I'm going to call the O'Reilly store just up the street & see if they have one & I'll pick it up today.
Thanks again, Bruman...
  #13 (permalink)
Old 02-12-2012, 03:09 PM
I was just looking at the box, my bad, add a 0 to that number 398001
  #14 (permalink)
Old 02-12-2012, 07:49 PM
Thanks again! I just picked it up about 5 minutes ago, $22.95.
Bruman!!
  #15 (permalink)
Old 02-13-2012, 11:21 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Quote:
Where I come from, when you end up on your back on the floor of your truck looking up between the heater and the firewall it's considered dys- functional....
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
Tags
100, 18476a, 1957, 19571960, 1959, 1960, b7tt, b7tt18476a, connection, core, diagram, ford, heater, hose, obsolete, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
