Rough erratic idle with SES light on.
1999 F350 7.3 diesel 150 k miles. Service engine soon light comes on at start up. Run smooth at 750 rpms. If I push on the accelerator peddle the rpm will shoot up to 1500 rpms and go back down to 750 with the peddle held down. After approximately 1 minute the engine will serge (kind of catching itself from stalling) and then will run with a miss rough at idle 750 rpms. The SES light goes off at this serge. I have recently changed glow plugs, valve cover gasket/wire harness, added anti gell to fuel with a full tank of fuel and changed the Fuel filter (which didnt look bad but I did it anyhow. Starts good now with new g plugs in the cold. At times the engine just quits at the serge when the Truck does not catch itself. Some times the ses light is on from start up and I will drive it down the road and all of a sudden its like a potato gets blown out of the tail pipe with a serge in power and the SES light goes off. Will then run OK. It also was as though I was running out of fuel even though showed 1/4 tank and I filled it up and ran OK for the rest of the trip approximately 1 hour more. Does this sound familiar to any one.
Obvious question would be what is the code...Kinda sounds like an injector or 2 not firing while cold, will it do this if it has been plugged in for a few hours, or after the motor is up to operating temp?
As for the 1/4 tank acting like it is running out of fuel, that is pretty common if the intank duckbill is cracked, or the pickup foot is missing or broken.
Is the engine oil full?
These are the codes that were pulled:
p1280
> p1690
> p0500
> p1670
> p1316
> p1248
> p0470
> p1211
> Abs memory codes
> C1145
> C1230
> C1237
> C1148
> C1229
>C 1226
> Gem sjb memory
> B1840
> B1371
> B1318
> B1446
> B1476
>B 0500
> B1203
> B1201
The truck ran the same today. Started out as I have listed above and then when warm ran quite perfectly :-)
What's up with these codes?
Where is the link to the list of Descriptions for the codes?
Thanks for the help.
p1280
> p1690
> p0500
> p1670
> p1316
> p1248
> p0470
> p1211
> Abs memory codes
> C1145
> C1230
> C1237
> C1148
> C1229
>C 1226
> Gem sjb memory
> B1840
> B1371
> B1318
> B1446
> B1476
>B 0500
> B1203
> B1201
These were the codes that were there. They cleared them and then I drove it for the remainder of the day. When running bad, runs like running out of fuel, shaking serging violently then when warmed up runs fine. I guess I need to go get the codes checked again in the morning to see what still comes up.
the P1316 means that the IDM has stored codes, here is a link to codes
Welcome to guzzle's Diagnostic Trouble Code list Web Page
you have some codes for injectors as well as high pressure oil, I would clear them and see what comes back first. Can or have you performed a functional test Buzz test, or cylinder contribution test?
I have checked the uvch on the pass. side yesterday and all was tight. I have been reading a lot of info on the ipr and the hpop leak. I have an indication of a rear seal leak but I replaced it last year while changing the Torque converter that disintegrated. Maybe the hpop. I don't have the capability to do the functional tests listed above. I will have the codes checked in the morning and check back. Sounds a lot like the IPR valve based on my reading of the forum pages.
