headlight switch problems- on f450 superduty
I know that its common for the headlight switches to overheat and after replacing mine I have noticed that the harness got too hot as well as the back of the fuse block. Is there anyone who does an upgraded aftermarket harness for these trucks?
Truck is a 95 superduty(450) with a 7.3
Ford has discontinued the harness
thanks for the links, but I do have another question re the harness part number. My mechanic took the dash apart and wont do any aftermarket repairs, he only will repair it with another ford harness due to liability issues. I had a 97 harness but it had a few extra pins in the main computer plug. I am told any 94-95-96 harness from a 7.3 will work but 97 wont. Is there any truth to this?
My existing harness part number is F5TB 14401 E77825G-EN
Have a line on another one but part number is F5TB 14401 (remaining numbers are different)
I am wondering if this harness will work and if the remaining numbers on the tag are just specific to that trucks vin or serial number? Any help is greatly appreciated
I might end up having to do it myself. He took the whole dash out etc and found out that there was a difference in pins from the original harness with the one that we thought would work. I wish I had known that it wouldn't work before he took the dash out. Now he wont do any repairs except replace the harness with the exact one that is in there. Thats nice since ford no longer makes that harness with that exact number. Now I will end up getting my truck back in pieces. Hopefully I get them all.
The headlight switch got hot and cooked the backside of the switch plug. And the fuse pannel where the flasher plugs in melted as well. Aside from that the harness seems fine. 40k mile 7.3 F450 way too much life left to give up on this truck
on
https://www.ford-trucks.com/forums/1...t-upgrade.html
yeah,that's new old stock.them things have been reported to go well over a half million miles (yes literally) before being scraped.
time to learn more about the basics of the truck,and perhaps pickup some more tools.there isn't much the average joe can't handle for maintenance or repairs on their own for these old trucks.
https://www.ford-trucks.com/forums/forum117/
oh.fyi:
Duralast/Headlight Switch Connector
Part Number: 262
from autozone.
this is the one i used when replacing my switch.i saw mine was burning up too.
direct replacement.hassle free.cut and crimp new connector on and done.
oh.fyi:
Part Number: 262
from autozone.
every ford that i own did the same thing and i just wired up some heavy duty push N pull switches for the headlights and running lights and have never had any problems since !
COLE HERSEE #
50088 Headlamp Switch
Extra Heavy-duty: SPST
Off - On, normally Off. 30A at
12V DC, 6-36V DC. Energizes
two circuits simultaneously
from a common feed for headlamps
and taillamps. Brass mounting
stem, 7/16" -28 thread. 5/16" (7.9mm) long.
Black plastic ****, 10-32 thread with set screw.
Zinc housing. Silver contacts. Sealed with a gasket under
the terminal insulator. Mounting hardware included.
COLE HERSEE #
Received 3,101 Likes
on
I am still having problems with my headlights, I know you guys gave me some good info but I am not great with electrical, and I will upgrade later. For now I am not really looking to upgrade my lights just trying to get the stock stuff to work as it should. Trying to figure out how this system works. What is going on is this-
If I pull the headlight switch out 1 click to the running lamps position, they do not come on. If I pull the switch out another click (all the way out)to the headlight/running lamp position, only the headlights come on, BUT if I push the switch back in between positon 1 and 2 I can get the running lamps to come on and the headlights to stay on as well. Works fine until driving down the road and the vibrations make it malfunction.
After removing the headlight switch there is a pin on the harness plug that is a little brown discolored, but the plug is not melted and the wires look fine. The discolored pin is in the middle of the plug with a brown/with white stripe wire. I was told this wire runs the running lite portion of the switch but they still work the same even if I disconnect this wire. I bought a new upgraded plug from Ford and replaced the old one with the upgraded one, as well as a new headlight switch. Still having the same problem.
After removing the dash harness the only other problem I see is the backside of the flasher on the fusebox got real hot and melted. There are two wires that go into that portion of the fuse box that cooked. My flasher do not work they just stay solid if you turn them on. I am not if these two wires go to the steering column yet. I am thinking they do. These wires are not brown /white stripe, so I do not think this is the cause of my headlight problem. I took pics but still trying to figure how to post them. Any help would be greatly appreciated, especially since all my mechanics dont seem to have a clue how to fix this problem.
Upload your pictures to a free hosting site like "Photobucket" for example but there are others.
Then simply copy and paste the images URL (IMG code) into your post and they'll appear in the thread/post. There will be options under the picture in your album, that is where you will get the IMG code.
Do so for every picture you wish to post, each picture you upload will have its own URL.
on
you may want to check out your multiswitch.
