Where is the crankshaft position sensor located?
Old 01-03-2012, 08:41 PM
sig40's Avatar
sig40
sig40 is offline
Originally Posted by jst
got my ficm back today, installed and short test run. working good.
If you don't already have one, get yourself a ScanGauge II and monitor the voltage. Also the engine oil temp.
Old 01-03-2012, 08:44 PM
sig40's Avatar
sig40
sig40 is offline
If you don't already have one, get yourself a ScanGauge II and monitor the FICM voltage. Also monitor the engine oil temp.
Old 02-25-2013, 10:53 AM
Ken Stokes's Avatar
Ken Stokes
Ken Stokes is offline
2006 Ford F350 diesel won't start
My ford F 350 cranks well, but won't start. It seems like it is about to, but just keeps turning over with no start. I have read that this may be from the IPC to the CPR and honestly the amount of answers i have seen would probably cost a fortune by the time i went through them. any real help out there?
Old 02-25-2013, 01:53 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Ken,
You may want to start a new thread for this.
Anyway, Do you have any gauges like the Scanguage II so that you can see live
data? That would be a good place so start and also reading in the Tech Folder
https://www.ford-trucks.com/forums/3...ch-folder.html
The one on no start.
Sean
talltorontoguy
1997-2006 Expedition & Navigator
06-24-2015 10:06 PM
JOHN2001
08-09-2012 09:21 PM
michelle85
1997 - 2003 F150
01-18-2011 09:46 AM
grinekb
09-17-2009 09:26 AM
jcurrie
08-08-2005 11:17 PM
Quick Reply: Where is the crankshaft position sensor located?
