Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-28-2011, 09:57 AM
Quest8205 Quest8205 is offline
Garage is empty, add now
Quest8205 is starting off with a positive reputation.
02 Explorer 4.0 xlt Fuel Pressure
Hi all,
could anyone tell me the proper fuel pressure for my truck? Having some rough idle and a little hesitation.
  #2 (permalink)
Old 12-29-2011, 01:01 AM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
Around 35 psi at idle with the manifold vacuum applied to the pressure regulator, around 40 psi with the vacuum line removed, or engine under load.
  #3 (permalink)
Old 12-29-2011, 02:41 PM
Thanks for the responce, that's what I'm reading. My codes were lean on both banks and lack of switching rich on bank one. I then removed my 02s at the connectors and the truck ran better so I then switch the bank 1 02 to bank 2 and the bank 2 02 to bank 1 and the only code I've gotten so far is lack of switching lean on bank 2 now. Does that mean that the lack of switching 02 sensor is bad?
  #4 (permalink)
Old 12-29-2011, 03:21 PM
It sounds like the O2 sensors are not responding properly; one worse than the other. How many miles do you have on the engine? Does your owner's manual say anything about how often the sensors should be changed?
The other possibility is that the MAF sensor is dirty, throwing off the A/F mixture far enough that the O2 sensors become ineffective. You can try cleaning the MAF sensor carefully with the proper cleaners to see if it helps, before you start changing parts.
  #5 (permalink)
Old 01-01-2012, 08:38 PM
You were right on. Replaced my 02 and she's running great.
  #6 (permalink)
Old 01-01-2012, 08:39 PM
I did try cleaning my MAF first btw but it was the sensor.
  #7 (permalink)
Old 01-02-2012, 03:51 AM
Glad that the fix was simple. Happy motoring.
Tags
02, 2003, 2006, 40, explore, explorer, ford, fuel, gas, liter, pressure, presure, psi, regulator, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
