5.4L coil pack (coil over plug)
Old 12-28-2011, 08:29 AM
DaGuru373's Avatar
DaGuru373
DaGuru373 is offline
Question 5.4L coil pack (coil over plug)
Hello club FTE. members.............
Im currently replacing my plugs boots springs and Ect.
What I want to know is if there is a specific resistance (Ohms) rating or a range that a good or acceptable coil should be at ?
I have checked 4 of the 8 at room temp. and all read 7 Ohms but does ANYBODY know specificly the acceptable number ?
Thank you..................Jc.
Thats checking from pin to pin on the connector btw...
Old 12-28-2011, 10:57 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
Typically and in my experience with a known bad COP checking DC resistance isn't a reliable indication of anything. I've had known bad COP's check out just fine with a DVM.
The best way to test is either in operation---you'll notice a misfire or using sophisticated electronic diagnostic tools. While the vehicle is running carefully disconnect each COP from the wire harness to see if a noticeable change happens---if not the COP is good.
HTH
Old 12-28-2011, 02:51 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
The newer engine computers that drive these cop systems are usually smart enough to detect a cylinder miss-fire, and will tell you which cylinder it is. It's true, a regular volt-ohmmeter doesn't have a high enough voltage to fully test the insulation integrity of the coils.
smmuttyy
Modular V8 (4.6L, 5.4L)
18
01-10-2019 06:59 PM
kennedy 44
08-15-2014 12:28 PM
rbrad6937
08-13-2011 05:35 PM
msm7c
1997 - 2003 F150
11-14-2006 07:27 PM
speedovr55
12-11-2004 02:28 PM
Quick Reply: 5.4L coil pack (coil over plug)
