Steering wheel swap - Ford Truck Enthusiasts Forums
Steering wheel swap
Old 12-27-2011, 10:49 PM
FallstonYJ's Avatar
FallstonYJ FallstonYJ is offline
FallstonYJ is starting off with a positive reputation.
Steering wheel swap
I think its been about a year since I last checked so I thought I would take another shot.
Does anyone have any experience or information on swapping a steering wheel with the hvac and audio controls in to an EX without controls? I have had the new steering wheel for well over a year but have been hesitant to tear in to the swap because I have never found any definitive info. on here about it.
Thanks for any help,
Tom
Old 12-27-2011, 11:11 PM
Sunline Fan's Avatar
Sunline Fan Sunline Fan is offline
Excursion Fleet Manager
Sunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputation
I know what you mean. I took a shot in the dark here, and so far so good. I intend to take the radio out of my new Ex and put it in this one to see if the radio controls will work.
http://www.ford-trucks.com/forums/10...xs-how-to.html
Old 12-27-2011, 11:26 PM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
Tom
I think you have to have the electronic HVAC controls...and the right wiring harness. Does yours have the electronic controls on the dash?
Old 12-28-2011, 12:57 AM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
1. You have to have the harness inside the steering column...or install them like Sunline Fan did
2. The harness has to run from the column to the radio
3. Your radio has to be capable of this
It's really not that hard to do. just make sure you have all 3 of the above. The link above is good reading. I've been prepping a similar swap for my 06 F-250 to use a F-150 wheel. Some day I'll tear into it and do the darn thing
Old 12-28-2011, 08:21 PM
So the radio then sends the signal to the heater/ac controls? Wouldn't he also need to have the electronic heat/air and a connector for that?
Old 12-28-2011, 08:32 PM
FallstonYJ's Avatar
I am assuming I have the electronic HVAC system even though I don't have the steering wheel controls. It has the auto temp feature and you set the desired temperature with digital readout on the dash?
I find it hard to believe that the necessary harness would not already be in place for the steering wheel controls. Can't believe they would wire each truck differently based on which steering wheel it receives but maybe that's just wishful thinking??
One of these days I will dig the box out with the new steering wheel in it and just dive in!...........(Just need to make sure I won't need to drive the EX for a couple of days in case I have problems.)
Old 12-28-2011, 08:50 PM
Ok, so you do have the controller, now do you have the harness? I wouldn't be shocked to see the harness not there. Everything in assembly lines are 'modular', and if the manufacturer can save money by not including another 50 feet of wire that would sit unused, they WILL save that $1 in materials.
Think of it...you pay the raw material cost, then additional time (labor) making the harness just to not use it. Why do that if you don't need to?
In any event, if the wires are NOT there, then you should still be able to add the harness leads. Not saying it would be easy (might be fairly difficult in the 'cut knuckles' department), but it could be done. I'd imagine so long as it doesn't have to go through the main computer (GEM/ECM/some other acronym) that it can be added.
Old 12-28-2011, 09:44 PM
FallstonYJ's Avatar
I am sure you are correct......if they can save $1 per vehicle they will. I guess I just need to do more research and try to have everything on hand that I could possibly need before I open her up.
Thanks for your input!
Old 12-28-2011, 11:13 PM
If I were you, I'd check the Ford parts web site and get as many exploded views that you can...and if you are lucky you can find a crashed X at a pick and pull and do a little 'exploratory surgery' while you are there.
So long as you don't destroy parts or steal anything, I'd imagine the owner wouldn't have a problem with you operating on a cadaver truck to learn what you are going to get into on your own.
Old 12-28-2011, 11:29 PM
Yes, you have the electronic HVAC. The other style has three manual *****, one for fan, one for temp, and one for where the air comes out and if it does. They put that style in the earlier Limiteds, but it remained in the XLT when the electronic version came out.
As long as you take the time to disconnect the battery, pull the airbag, pull the steering wheel, pull the clockspring, and then replace with the new clockspring, steering wheel, and then the airbag, you can leave the wiring for later. The plugs for the airbag parts are the same between the two, so you can still drive the truck complete with airbags. You'll just not have horn, cruise, or any of your new buttons until you wire it up.
Old 12-28-2011, 11:35 PM
Sunline Fan...so what is involved in adding the electronic heat/ac controls...can it be done to a Limited that has the old manual style?
Old 12-29-2011, 12:01 AM
That I don't know. I imagine it would be somewhat difficult, but I really have no idea how the manual style works. I've never had one. If the manual style doesn't have vacuum operated blend doors (are they cable driven to the *****?), then it would be really involved. If they are vacuum operated doors that are computer controlled and the ***** are just a different way to input what you want, then it might be possible without major mods.
Old 12-30-2011, 09:17 AM
FallstonYJ's Avatar
Does anyone know the correct Ford part # for the clock spring that works with the steering wheel controls?
"If I were you, I'd check the Ford parts web site and get as many exploded views that you can...and if you are lucky you can find a crashed X at a pick and pull and do a little 'exploratory surgery' while you are there."
Is there a specific web site that you are referring to?
Thanks for all of the replies thus far!
Old 12-30-2011, 11:33 AM
Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
Old 12-30-2011, 11:35 AM
They were in my 97 Expy (the Expy had a pinhole leak in the blend door, so I pulled the controls to to try to find the leak).
Late 80s Steering Wheel on 94 willstutely 1987 - 1996 F150 & Larger F-Series Trucks 5 12-29-2016 10:09 PM
Steering Wheel Upgrade or Repair 651_F350_KR 6.0L Power Stroke Diesel 11 09-23-2016 09:54 AM
Mustang steering wheel? geearturi Aerostar 5 04-27-2016 04:20 PM
Steering wheel Swap firestroker8706 1999 - 2003 7.3L Power Stroke Diesel 14 12-05-2010 11:45 AM
Steering wheel swap; adding audio/hvac controls FallstonYJ Excursion - King of SUVs 11 07-10-2010 10:08 PM
Tags
05, 1966, 2005, 350, duty, excursion, f150, f250, ford, interchange, platinum, steering, super, swap, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
