1999 Expedition Liftgate Glass Will Not Open - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-27-2011, 10:20 PM
Marcos_M Marcos_M is offline
Marcos_M is starting off with a positive reputation.
Hello all. Let me begin by saying that I have seen the search box and I understand many people have had similar problems. However, I haven't yet seen anyone with my problem or a solution that would work for my problem.
My problem is that the lift-gate glass will not open. The entire door opens just fine and locks and unlocks as expected, but when i turn the handle to open the window, it turns but nothing happens. I don't hear anything engage, the **** just turns. I understand that the solution to these problems usually involve removing the trim panel from the rear door. I also know that to do that, I need to remove two screws that are behind the glass. Therein lies my problem. I can't remove the trim panel because i cant open my glass. So my question to you all REALLY is
Is there any other way to get the glass open or to get access to these screws? Is it possible to jimmy the window open from inside or some other method of opening the window?
Thanks in advance,
Marcos
Old 12-28-2011, 03:09 PM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
I think those screws are for the weatherstripping, not the trim. You should be able to remove the trim without opening the glass or the entire rear hatch for that matter.
Old 12-29-2011, 12:46 AM
I'll have to try when I get back to the states.
2004 nagivator rear wiper problems. vickers57 1997-2006 Expedition & Navigator 2 02-23-2016 12:07 AM
2003 Expy Rear glass won't open - int lights stay on. SRobo09 1997-2006 Expedition & Navigator 5 04-15-2011 10:13 PM
Can't open liftgate lock on 2004 Explorer JADA Explorer, Sport Trac, Mountaineer & Aviator 5 11-09-2010 08:35 PM
Installation of Door Window's Part's Customcab 1961 - 1966 F-100 & Larger F-Series Trucks 29 11-24-2008 09:55 PM
Expedition rear liftgate won't open Ford416 1997-2006 Expedition & Navigator 4 05-18-2008 07:22 PM
Tags
1999, 99, back, door, expedition, ford, gate, glass, lift, liftgate, open, rear, window, wont, working, wount
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
