Lowering 1992 F150 - Ford Truck Enthusiasts Forums
Lowering 1992 F150
Old 12-27-2011, 02:40 PM
t_hess66 t_hess66 is offline
t_hess66 is starting off with a positive reputation.
Lowering 1992 F150
Alright so far, for lowering my 1992 F150 I've got a belltech rear flip kit and belltech I beams for the front. What is the flip kit good for in the back, 5 or 6 inch drop? I've seen people say both.... however I want a 4/6 drop, so if its only good for 5 in the back im going to need drop shackles. Now for the front is my question, how should I lower that other inch? Coil springs? Possibly lightning coil springs? I still want to be able to align my truck haha. Thanks
Old 12-27-2011, 02:54 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Yes flip kit is for 5. Shackles will get you the other inch. You will need to notch your frame also. For front lightning coils or 1" drop coils.
Old 12-27-2011, 03:01 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe Bootlegger's Deluxe is offline
Bootlegger's Deluxe is starting off with a positive reputation.
i went 5/5 on my 95 F150, i went beams and L springs in the front, and the flip in the rear ...
i say do the flip and the beams, and the L springs, and see how well you like it for awhile. I was going to go down another inch in the rear, but i decided not to and am happy with the results.
BTW, with my 5" rear drop, i didnt notch the frame... i just removed the bumpstops. Havent had any problems in 9 months of driving ...
Old 12-27-2011, 03:33 PM
bootlegger, can you post a picture?
Old 12-27-2011, 04:00 PM
86, do you think the belltech drop spring will be too much of a drop, its supposed to be a 2 inch drop. Would the alignment be thrown off too bad with the 2 inch drop? Im trying to find someone who makes a 1 inch drop coil, but no luck yet. Or where could I buy new lightning springs?
Old 12-27-2011, 04:27 PM
86F150302's Avatar
Good luck finding NEW lightning springs. Some come up on nloc from time to time. You might be able to go with the 2" drop coils and get new alignment bushings. When I'm on my computer ill post a link.
Old 12-27-2011, 04:48 PM
Thumper19's Avatar
Thumper19 Thumper19 is offline
Thumper19 is starting off with a positive reputation.
lol people never browse the classifieds here. I have a set of 1" drop coil springs for 87-96 f150's for sale. Just need painted as they are raw metal. I can send you a pic via txt message. $70 shipped is what I am asking
I lowered mine 4.5/6 and had front coil springs custom made. Cost a pretty penny but I like the way it looks and I did not notch my frame just removed bump stops and put small ones on. This is front with stock tires, also no problems aligning it. I have stempf automotives adjustable camber bushing and its good up to 4*. Also I did have the belltech 2" drop springs and they made me have tire rub.
Old 12-27-2011, 04:53 PM
Thumper19's Avatar
I could also sell you the alignment bushings as well if not you can find them on ebay.
$62 here
EXTREME FULLY ADJUSTABLE ALIGNMENT CAMBER CASTER BUSHING KIT 2WD 2X4 4X4 4WD SET | eBay
I could get you some for 60$ shipped
Old 12-27-2011, 09:46 PM
Im perfectly fine with using 2inch belltech drop srings, as long as i can get alignment bushings that work.
Old 12-27-2011, 10:38 PM
any reputable alignment shop should be able to get you back into specs ... i speak from experience, i'm a guy who does alignments for a living...
heres my silver 95, i've since put some slightly shorter tires on it ...
Old 12-27-2011, 10:40 PM
Quote:
Ive never seen a set for sale other than from NLOC ... i know i've bought two sets there ... but the question is: what will i do when they eventually wear out?
Old 12-27-2011, 10:56 PM
86F150302's Avatar
Quote:
I guess get coil spring specialties to make you up some.
Old 12-27-2011, 10:59 PM
That truck looks awesome, nice work bootlegger. Looks like i'll be getting the 2 inch drop springs from belltech which will make for a 5/6 drop. Does anybody have pictures of a 5/6 drop?
Old 12-27-2011, 11:40 PM
Quote:
Thanks for the appreciation! It drives great too!
Old 12-28-2011, 07:14 PM
In this stylin trucks catalog I have in my hands, it has a belltech 5/6 drop for 87-96s that uses a flip kit only. No drop shackles to get 6 inches. See what I mean about some places it says 5 inches, some places it says 6?
C-notch fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 12 07-01-2015 08:22 PM
lowering a 1990 f250 long bed Brian Fulcher 1987 - 1996 F150 & Larger F-Series Trucks 1 05-01-2015 10:27 PM
Lowering 1992 f150 help? K3NN3DY 1987 - 1996 F150 & Larger F-Series Trucks 31 03-06-2014 12:59 PM
Wanting to lower 1992 Flareside K3NN3DY 1987 - 1996 F150 & Larger F-Series Trucks 0 01-15-2013 06:31 PM
lowered 89 progress Thumper19 1987 - 1996 F150 & Larger F-Series Trucks 28 09-27-2012 11:01 AM
Tags
1992, 56, 92, beam, bushings, camber, coil, drop, dropped, f150, ford, inch, lowered, lowering, slammed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
