Color of Transfer Case Fluid - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 12-27-2011, 12:24 PM
mullins13 mullins13 is offline
mullins13 is starting off with a positive reputation.
I just took my 2006 Navi to a quick service oil change location. While there, they checked my differentials and transfer case fluid. The tech mentioned that the fluid in my transfer case is brown and looked like gear oil and that it should be red like the transmission fluid.
I had the transfer case fluid changed in the spring at the dealership, could they have added the wrong fluid? If it was the wrong fluid, wouldn't the transfer case be damaged by now, especially after a summer of towing my 5000lb traniler 1500mi?
Old 12-27-2011, 06:47 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
ATF is correct for your T/case and it will change color with use and heat. Check it by feel and smell. If it is real thick and has a greasy smell it is likely gear oil and you might want to file a complaint with the dealership just in case there is any damage. Then change the fluid and save a couple of ounces of the old fluid for testing if you or Ford wants to check it.
Old 12-28-2011, 05:59 AM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
Look at my link at the bottom of my post. My fluid came out the same color. However, when I changed the fluid, I don't think it had been changed in the 12 years before I took ownership.
Transfer case oil sxrfun 1999 to 2016 Super Duty 7 11-12-2015 09:42 AM
what kind of oil is in the transfer case?? jdhudall 1997 - 2003 F150 2 03-28-2013 07:59 PM
gear oil cws10190 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-05-2012 10:00 PM
transfer case fluid/oil ? XxWINxX94 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-20-2011 11:10 PM
transmition and transfer case fluids mklemin 1994.5 - 1997 7.3L Power Stroke Diesel 3 05-07-2008 03:31 PM
Tags
1999, 2011, 78, brown, case, color, colour, escape, expedition, f150, fluid, ford, oil, tranfer, transfer, transmition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
