C1095 - ABS Pump Motor Circuit Failure - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-27-2011, 10:15 AM
Pocket Pocket is online now
Pocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputation
This is the code that has come up on my truck, and keeping the ABS light illuminated. It came on a few weeks ago. Wife said she was driving, someone cut her off, and she had to slam on the brakes... resulting in the light popping up and staying on.
Anywho, brakes seem to work fine. I recently replaced the pads and rotors, but I can't get the light to go away. Not sure if it's an actual pump failure, or if it's just an electronic/sensor failure.
Any tips?
Old 12-27-2011, 10:45 AM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
An ABS motor failure won't affect normal braking, just the anti-lock feature won't work.
Old 12-27-2011, 10:55 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Here are the pin point tests for that code.
Anti- lock Brake PINPOINT TEST J.pdf
Old 12-27-2011, 11:05 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Curtis,
This s a strange one. Don't understand why slamming on the brakes would cause ABS problems, but:
Did you check Fuse 25 10A Mni and Fuse 602 60A Maxi?
There must be an electrical connector that goes to the ABS module. Somethng has to operate the solenoids for the propostioning valves.
Reseat that sucker.
I can't find the ABS module wiring on any diagrams.
I wonder if by "Hydraulic pump" they are referring to the PS pump for the hydroboost.
Edit: Clux and Roland beat be to it while I was going on and on.
Here's some info Roland posted about ABS sensors.
Front ABS Sensor Ohm reading across the Sensor End connection
4x2 F250/350: 2,000-4,000 ohms
4x2 F450/550: 650-800 ohms
4x4 F250/550: 650-800 ohms
Rear ABS Sensor (VSS) Ohm Readings
All: 800-3,500 ohms
Wish I could be more specific, but like you, I have never seen that code before.
Clux and Roland beatme to it while I was
Old 12-27-2011, 11:10 AM
nissandoc's Avatar
nissandoc nissandoc is offline
nissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to all
Looks like if the code returns after clearing it then you just have to replace the abs unit. Probably a sticking valve/actuator inside. I would try an adjustment with a BFH before I replaced it.
Or supply direct power to the pump circuit and see if it runs.
Old 12-28-2011, 07:46 AM
Some really good info here guys. Thanks! I appreciate it.
Now to find the time to actually try diagnosing and fixing the problem.....
2007 Ford Edge ABS, Traction Control, and wrench lights on. ReBilld Crossovers 2 04-29-2016 11:14 PM
2000 F350 brake issues Cannon500 1999 to 2016 Super Duty 3 01-24-2014 10:47 AM
ABS Light On Multiple Codes SuperMike 1999 to 2016 Super Duty 0 01-23-2012 05:03 PM
2002 F250 Big ABS Problems! Codes B1676 C1185 C1096 C1198 C1214 C1206 :( BltFordTough 1999 - 2003 7.3L Power Stroke Diesel 3 10-30-2010 06:18 PM
02 f-150 ABS lIssues windstar99 1997 - 2003 F150 3 08-06-2008 12:42 AM
Tags
1095, 2000, 2001, abs, c1095, circuit, code, f150, failure, fault, ford, hydraulic, motor, pump, ranger, taurus, trbl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
