Do the 302 and 351w have the same Bellhousing and Motor mounts? - Ford Truck Enthusiasts Forums
Old 12-26-2011, 11:20 PM
cbr3 cbr3 is offline
cbr3 is starting off with a positive reputation.
I have a 1995 Jeep Cherokee that I am looking to swap a SBF into. The only swaps I can find online are 302s. I was under the impression that the blocks are very similar. I have no problem with a 302, but my grandpa has an '86 F150 with a 351w HO 4BBL that I could get running. Also, what kind of fuel economy would a 351w HO have in a 3000 pound Jeep? Thanks.
Old 12-26-2011, 11:34 PM
HemiEater's Avatar
HemiEater HemiEater is offline
HemiEater is starting off with a positive reputation.
yes..........
Old 12-27-2011, 12:05 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Depends upon tire size and gearing.. but generally don't expect anything too remarkable.. like 12-13mpg city and maybe 15mpg highway if you keep it under 2000rpm at cruising speed.
Old 12-27-2011, 12:09 AM
Dang, I expected it to be quite a bit better than a 5000-6000lb truck. Maybe I'll go with a 302 then. I've got time to decide, as I won't be able to afford it until the summer.
Old 12-27-2011, 12:18 AM
Ken(Ark) Ken(Ark) is offline
Ken(Ark) is starting off with a positive reputation.
You can find the 302's with the factory roller cam set up at good prices these days . 25 free horsepower that doesn't get lost due to lifter friction .
Old 12-27-2011, 12:19 AM
Conanski's Avatar
If the jeep has reasonable gearing it should be a bit better than a full size truck, but not a whole lot.. a jeep has even worse aerodynamics than a pickup so being lighter only helps at lower speeds.
Old 12-27-2011, 12:27 AM
Quote:
Yes, I'd like to find a roller cam HO 302, the carbed 351 is just more easily acquired. I would prefer the EFI though, and I've heard that the late 80's Mustangs had one of the easiest EFI systems to work with, that it is basically a stand alone system.
Old 12-27-2011, 07:22 AM
HemiEater's Avatar
why r u worried about fuel mileage, your putting a V8 in a Jeep... whats wrong with whats in it??
Old 12-27-2011, 12:43 PM
Quote:
I knew someone was going to say that. I love the 4.0 inline six that's in it now, but I want some more power, especially when I put 33's on it. Now, I could go the stroker route and build a 4.5, 4.6, or 4.7, but as is it only gets about 13.6 mpg. I love the idea of a powerhouse I6 what with the massive torque and all, but it would probably get about 10mpg on a good day. Back when I wanted to build a Foxbody Mustang (read: before I fell in love with my Cherokee) I was seeing that guys with 300 horse 5.0L's were getting high teens in the city and mid to high twenties on the highway.
I was thinking I could put in a SBF and get more power, fuel efficientcy (above 15 city would be good) and it would be lighter if I chose the 302. Also, I want v8 sound.
Old 02-14-2012, 07:19 PM
ThugRen ThugRen is offline
ThugRen is starting off with a positive reputation.
Upgrading the jeep from a 4L to a 5.7L is a big project!! You will be going from a Fuel injected system too a carb'ed system. Which isn't bad but if your doing any type of hill climbing or going down the hill's. But if your going too do it.
Are they both Standards or Automatics? Rad size? Are they both 4x4 version's?
Things you will need too start looking for is motor mount, torque converter(flex plate with clutch), exhaust, converting from fuel injection to carb, fuel pump, custom oil pan, tranny linkage adjustment set, tranny mount converter, the pulley's unless your going to use the Alt and Power Steering pump from the 5.7L(351W). If you have a Auto 4 Speed OD You are USING a RE420 Tranny and well you will need too rebuild that and Add a Bigger Tranny Cooler..
I have a 95 Jeep Grand Cherokee 4L. I was looking at doing that too with a 302(5L) but Wow.. Having the Engine is about the Cheapest part. Too Do the Convert it I was looking at a part bill some like $5000-6000.00.
Do yourself a Favor and get that Stroker 4.7 kit and add In a T3/4 Garret TurboCharger Kit, Custom Exhaust, Custom Intake, clean and polish the valves and head. It will be cheaper and it will give you more power with a lot less headache's. I hear you on the 4L power issue with the bigger tires. The Turbo will give you the power where you need it which is at the 2,000 Rpm too 5,000 RPM.
If you do that 5.7L in there, you will be blow axles, gears, tranny, T-Case, Drive Shafts, and twist up your frame.
Cam and pushrod question for 351w Krisverde Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 08-19-2015 02:06 AM
302 swap to 302 HO in my 1986 F150 Gunner 86 Engine Swaps 8 08-28-2011 06:43 AM
302/351 swap into older Jeep CJ. ToughestTruckBuilt Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 08-04-2011 11:55 PM
302 to 302 HO swap muddyford911 1987 - 1996 F150 & Larger F-Series Trucks 17 05-29-2009 01:39 AM
What cams in my 96 F150? droppedf100 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 04-25-2005 05:25 PM
Tags
1973, 302, 351, 351w, cbr3, cleveland, engine, ford, hd, ho, motor, mount, mounts, mustang, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
