Update on Project: Six Shooter :)
#46
#49
Well, yes it will. Without utilizing the provision for heating the intake you most likely will end up with drive-ability problems that cannot be tuned out with the carburetor. Best get a plate fabricated with hose barbs now and mount it on the intake before you install the intake otherwise it will be a PITA to do so after the intake is installed. AB and F-250 restorer have pics of the plate posted in several threads.
#50
I completely agree, and would definitely recommend some type of heat. However, not having something there, and not covering it, won't cause any other adverse issues, such as intake/exhaust leaks, and the like. It'll just be an unused cavity. At least, I think that's where the question was oriented.
#54
I'm curious why you 'cut' the alt bracket?
Also, before you hook up the alt, you should 'clock it.' It will take 2 minutes to do it. All it is is loosening the 3 long bolts in the back of the alt that hold the shell together, and turning the back clockwise until the bolt holes line up again, then tighten them back up. That way the wires exit from the bottom and not the top, and look more professional.
#55
I cut the alt bracket because before I had the factory air pump and since it wasn't going to be used anymore I chose to cut it and it gives I cleaner look. I also believe I think the headers were going to rub on the old piece that was there. Thanks for the trick advise when I get it running I'm going to shoot a video of it.
#56
#57
I have yet to do that to my alternator bracket. I agree that it looks much cleaner when done. Nice work.
The engine looks great in there! When do you fire it up?
I'm sure you've taken every precaution. Double checked all the fluids. Primed the oil pump. Etc. etc.
Exciting stuff.
Exciting stuff.
but i will keep you guys posted! i still gotta buy i think three more things. the lokar throttle bracket, lokar throttle cable and this one was just added to the list a clutch slave cylinder. but other than that i think i should be all set oh wait i gotta buy some octane booster because when i sat it down i think i had a half tank of unleaded gas. in there.
#58
I wouldn't recommend turning over the entire rotating assembly to get the pump primed & filter filled, that will take a little while.
Even with the voluminous amount of assembly lube everywhere, getting oil where it needs to be as soon as possible is a Good Thing.™
