3.0 interchangeable? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-26-2011, 09:01 PM
lurchy98's Avatar
lurchy98 lurchy98 is offline
lurchy98 is starting off with a positive reputation.
Hi everyone,
My brother has an 04 3.0 5 speed. edge with a bad engine. He's found a wrecked 94 3.0 5 speed. to buy the engine from. My question is will the 94 and 04 3.0 engine interchange using the accessories and other miscellaneous items needed from the 04 engine? Has anyone ever attempted a swap like this. Any suggestions are greatly appreciated.
Thanks!
Old 12-28-2011, 10:31 PM
Dutter's Avatar
Dutter Dutter is offline
Dutter is starting off with a positive reputation.
I dont think so, Unless you change the electrical and ECU, cus im pretty sure the 04 3.0 was a OHC motor and i know that the 94 3.0 was a push rod motor. So most likely not, unless you mess with the electronics then im sure u can get it to work
93 and 94 3.0 trans...interchangable? MotorCityBolt Aerostar 1 11-02-2015 10:19 PM
Trans swap newmaac Clutch, Transmission, Differential, Axle & Transfer Case 5 05-23-2015 10:18 AM
3.0 Engines 61_racer 3.0L V6 1 05-15-2015 06:34 PM
67 flatbed 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-14-2014 05:19 AM
1993 ford ranger engine swap sknybird Ranger & B-Series 5 06-17-2011 07:03 PM
Tags
04, 30, 40, enterchangeable, escape, ford, forum, interchangable, interchangeable, mazda, moter, motors, ranger, series, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
