'78 and '79 Power steering fix!
#32
Ford actually had a recall on 78/79 steering gearboxes on the F-150 4x4's. My dad's steering had the same problem from just a few days after driving his off the lot (78 F-150 4x4, identical truck to earthquake's, motor, paint and all) back in November of 77.
#33
#34
#36
#37
#38
#39
I have 33 x 12.50 X15's on my truck and steering with it stopped is barely different than steering with it moving. A good pump and no air in the box will be the cure.
As far as putting a bleeder in, with my luck, I'd drill into something important. It may be a pain to get going, but once it is, it stays working for a LONG time. I'm on 6 months with ZERO issues. (knock on wood) I didn't think it was worth the risk to modify the box. Once it's properly bled, you're done.
#40
Ok. So I read this post a few months ago and tried the method on post 20. Seemed to work fine, however when it cooled down to below freezing the steering pump would whine until it warmed up a bit. No problems steering but the whine would wake up the neighbors. It started warming up and the whine disappeared. A couple weeks ago after a highway trip, I lost power steering for about 15 minutes. Came back and worked fine for about 2 weeks. This past weekend, on another highway trip I lost power steering again. It didn't come back until randomly one afternoon I had power steering for like 5 minutes then lost it again. Tonight, I used both the method mentioned in the first post, followed by the method in post 20. Steering seemed to work fine during initial 5 minutes of test drive then started to act up. no sounds just started to feel hard to steer. I let it sit for about an hour, checked the fluid level and went out for another test drive. I noticed during this ride the power steering seems to do much better at higher rpms. When coasting through a turn it would start to tighten up so I would shift to neutral rev it up and the steering would get looser. Anyone know what might be the problem? I don't want to just start throwing parts at it but I have a feeling something is broken. What do you guys think?
#41
Regardless, it sounds like the pump is going south.
#43
#44
Im having a problem with mine i have a 79 f150 4x4 and was wheeling and all my fluid blue out the pitman arm seal on the steering box just rebuilt it all new seals and while bleeding it, it blew the new seal could that have been because of air in the system im getting ready to replace the seal again and would like it to work this time. If you have any info please share it thanks.
