'78 and '79 Power steering fix! - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 09-23-2013, 09:36 PM
Jklnhyd's Avatar
Jklnhyd Jklnhyd is offline
Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.
My gearbox seems to be leaking. It is steering great, no issues at all. Does this sound like a simpler fix than what has been discussed in this thread?
  #47
Old 09-24-2013, 03:54 PM
Eaky's Avatar
Eaky Eaky is offline
Eaky is starting off with a positive reputation.
what do you do with a 78 f250 4x4 that had power steering when it was parked (no idea for sure just a few months i think) and now it doesnt maybe very little but not right for sure it doesnt have oversize tires either or a lift
  #48
Old 09-24-2013, 04:00 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Usually not. 'Might oughtta think about getting a quality rebuild unit from Redhead or Benchwork Steering.
Quote:
Originally Posted by Eaky View Post
what do you do with a 78 f250 4x4 that had power steering when it was parked (no idea for sure just a few months i think) and now it doesnt, maybe very little but not right for sure it doesnt have oversize tires either or a lift
I would check its fluid level and, whether the drive belt broke. You know, troubleshooting.
  #49
Old 09-24-2013, 04:04 PM
Eaky's Avatar
this may sound ignorant but ill ask anyway how do you check the pump itself i cant find anything wrong the fluid level is good and everything i didnt even have to add any to it
  #50
Old 11-02-2013, 07:42 PM
ccbrett's Avatar
ccbrett ccbrett is offline
ccbrett is starting off with a positive reputation.
Hey guys I have a 78 with 351m got it from a guy it needed a clutch put the clutch in and started it steering pump sounded awful just did the procedures in this thread pump is noisy but not as bad just wondering the damage was done already and I need to change pump thanks
  #51
Old 11-03-2013, 12:01 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Quote:
Probably. Hydraulic pumps don't like running without fluid in them. It scores the veins in no time at all. The bleeding will be easier if you don't pop the lines off the gear box. That way the fluid level stays above the box and doesn't create an air bubble in the box.
  #52
Old 11-03-2013, 01:56 PM
ccbrett's Avatar
Well installed new pump did the procedure no whine and good steering. Now I believe my gearbox could be bad I have some play in the wheel before the tires will turn.
  #53
Old 11-03-2013, 02:51 PM
Check the track arm and drag link before you condemn the gear box. The other two are MUCH more common. (I just replaced both of those in one of my '79's.)
  #54
Old 11-03-2013, 04:29 PM
ccbrett's Avatar
Cool I'll take a look. I can grab the steering column shaft under the hood it will move the the pitman arm will move it seems but ill Check closer.
  #55
Old 11-03-2013, 05:09 PM
pumpdriver20's Avatar
pumpdriver20 pumpdriver20 is offline
pumpdriver20 is starting off with a positive reputation.
Quote:
Originally Posted by hasteranger View Post
I'm bringin this back from the dead, but couldn't you just drill and tap the top of the box and use that as a bleeder? Or I guess, not as a bleeder, but to top off the fluid?
I was wondering this myself as I started reading through the thread.....
  #56
Old 11-03-2013, 07:44 PM
Quote:
You have to understand my luck. If I tried that, I'd drill through something important and wreck the gear box. Without any modification, this is the procedure.
  #57
Old 11-03-2013, 07:45 PM
If you had fluid leaking all over the gear box, you may want to throw in a new rag joint as well. Oil eats them.
  #58
Old 06-23-2014, 10:10 PM
Kuvrok's Avatar
Kuvrok Kuvrok is offline
Kuvrok is starting off with a positive reputation.
Talking Worked like a charm
I just wanted to give a big thanks to Earthquake68 for the 79 power steering fix. Holy crap I wanted to fix my steering so I got myself a Redhead, Borgeson steering shaft, and a new rag joint and pump. I tried the Ford way to bleed the pump a couple times, each time the pump puked out the fluid after a drive. I found this thread and considered this the last resort. I should have done this first! it worked instantly, it sucked a quart in as soon as I tipped the gear box up and started it up. If anyone is having trouble do this! it works! Thanks again for sharing.
  #59
Old 08-15-2014, 03:22 AM
Jughead1984's Avatar
Jughead1984 Jughead1984 is offline
Jughead1984 is starting off with a positive reputation.
God im having this same problem on a 76 4x4 I jus bought put a new pump on still turns shi**y Thanks for posting even tho mine is a couple of years older I think ive got the same problem. My dads 78 4x4 has the same Im not NOT gonna steer for you without you having to work for it problem lol after I try it on mine ill go see if I can get his to turn too. Thanks for sharring
  #60
Old 08-17-2014, 04:37 AM
BIGT94z's Avatar
BIGT94z BIGT94z is offline
BIGT94z is starting off with a positive reputation.
sub'd so I can reference it later on!
Steering gear install 99expyTN 6.4L Power Stroke Diesel 4 10-28-2014 01:07 AM
Steering Box Questions 76ClydeF100 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-23-2014 11:23 PM
power steering problem on my 1977 f150 tigs1977 Brakes, Steering, Suspension, Tires, & Wheels 2 10-06-2013 04:40 PM
partial removal of steering box? alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 28 11-01-2012 06:15 PM
Power steering flush - FIXED MY WANDERING Krewat 1999 to 2016 Super Duty 17 04-27-2011 11:14 AM
Tags
1978, 78, 79, air, conversion, courier, f100, f150, f250, ford, line, loose, power, problems, steering, sterring, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
