1977 F150 Heater Core Replacement with AC - Page 2 - Ford Truck Enthusiasts Forums
Old 12-31-2013, 05:29 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Bookmarked, just in case ..... great reminder if it's been 27 plus years ....
Old 01-07-2014, 10:31 AM
Carter78F150 Carter78F150 is offline
Carter78F150 is starting off with a positive reputation.
Thank you for great information! Will be doing this coming up shortly.
Old 01-07-2014, 10:42 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Subscribed for later info...great thread.
Old 01-07-2014, 02:14 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Forget the aluminum garbage heater core, hacking the OE gasket up and buying additional weather-stripping and use the correct brass core.
Ignore the "without air conditioning" they advertise, it is the correct core for A/C.
1973-79 BRONCO HEATER CORE - WITHOUT A/C - BRASS | Laurel Mountain Mustang
Old 08-31-2015, 09:27 PM
HeavyDinSC HeavyDinSC is offline
HeavyDinSC is starting off with a positive reputation.
I realize this is an old thread, but it was really helpful for me. I just changed out the heater core on my 1978 F100 Ranger. My project turned out to be a challenge until I finally figured out that I needed to free up the AC hoses (that connect to the condenser [or evaporator as the guy on North Country calls it]). Once I did that, I could move the condenser around enough to get at the heater core. Removing the air filter housing under the hood also allowed the condenser hoses to move more freely.
I opted to do this replacement because I had a leak coming out of the cover and most of the posts on this site indicate a problem with the heater core given those symptoms. We'll see.
I'm basically finished except I've got to put the thermocouple back in then the vent and then the cover.
After that, I've got to get coolant into the new heater core, but that part I haven't figured out. Does that simply go into the engine's radiator, or do I have to fill it elsewhere. Thanks in advance.
Old 09-01-2015, 09:59 AM
Wisdum, thanks for this information, photos and all. Just wanted to know how you refilled the coolant afterward. Can you explain that?
Old 09-01-2015, 03:00 PM
ZarK-eh's Avatar
ZarK-eh ZarK-eh is offline
ZarK-eh is gaining momentum as a positive member of FTE.
What happens if you remove that cover under the hood? Is the unit really ruined if removed? What's under it?
I'm looking at this piece and wondering if I can hack some of it out to clear the EFI intake manifold on my 4.9L 6cyl.
Old 09-01-2015, 04:56 PM
77&79F250's Avatar
Used OEM parts guy
He said air filter housing, as in carb air filter. Are you asking about the evap (big box) cover under the hood or that metal cover that is rived to the side of it?
What is under it.....the blower fan. and heater core for starters. I will post some detailed pics later on this afternoon.
Old 09-01-2015, 05:01 PM
77&79F250's Avatar
Used OEM parts guy
Found them. If you are not using the a/c set, just remove the big box all together and go to a heater core only set up.
Wala, tons of room.
Old 09-01-2015, 05:48 PM
77&79F250, good photos. I'm South Carolina, so I'm going to keep the AC intact. What I'm trying to figure out is once you pull and replace the heater core, and put everything back together, then how do you get the fluid back in the system?
Old 09-01-2015, 07:52 PM
77&79F250's Avatar
Used OEM parts guy
Take it to an a/c shop and have them service it. Might have them do a conversion from R12 to R134a (fittings) while it is there??? Or something like that, maybe Freeze 12, I think it is an cheap alternate to R12?
That is why there are a/c shops. lol
Old 09-08-2015, 12:21 PM
bkaul's Avatar
bkaul bkaul is offline
bkaul is gaining momentum as a positive member of FTE.
I think he's asking about the engine coolant, not the refrigerant for the A/C system. That, you just fill at the radiator. Idle the engine with the heater on to bleed the air out.
  #28
Old 05-21-2016, 02:57 PM
Mhowarth's Avatar
Mhowarth Mhowarth is offline
Mhowarth is starting off with a positive reputation.
Quote:
Wala, tons of room.
I have a 1978 f350 that's setup like this. I need to get the heat working but I would like to lose the AC. The previous owner removed the lines and condenser/pump? I would like to remove the big black box as well. What does the heater setup look like without that box? What do I need to do to completely remove that AC and have the heat working? Thanks
Matt.
  #29
Old 05-21-2016, 05:05 PM
77&79F250's Avatar
Used OEM parts guy
Remove the large a/c box set up and get a none a/c smaller box. Replace the heater core and the blower motor. You will still have the dash vents, but that is no big deal IMO.
  #30
Old 05-27-2016, 05:30 PM
shermy452 shermy452 is offline
shermy452 is starting off with a positive reputation.
Quote:
Matt.
I want to keep my facotry a/c but need the parts. If you are getting rid of the facotry a/c like the black box, things like that. I'M VERY INTERESTED!!!
heat problem on my 99 f150 jagger blaze 1997 - 2003 F150 8 11-18-2014 10:40 PM
'71 F250 w/ AC heater core Norton72 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-18-2014 10:28 AM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 03:05 PM
3 Months...3 Heater Cores Gone holymolie 1987 - 1996 F150 & Larger F-Series Trucks 22 03-29-2011 01:54 AM
Heater Core Size Issue Mudman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-25-2007 06:08 AM
Tags
1974, 1977, 1978, 1995, 77, core, f100, f150, ford, heater, instalation, motor, ranger, removal, replacement, replacment
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
