Need Help- Tie Rod Ends - Ford Truck Enthusiasts Forums
Old 12-26-2011, 03:06 PM
MConnelly MConnelly is offline
MConnelly is starting off with a positive reputation.
Exclamation Need Help- Tie Rod Ends
Hello, I am new to the forum and need some words of wisdom from those of you who have done this before.
I am replacing the outer tie rod ends on a 1959 F-250 and I was able to get the bolts out, but I can't seem to get the actual tie rod ends out. Suggestions, tips or how to links would be appreciated.
Thanks.
Old 12-26-2011, 07:59 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
By getting the bolts out, are you reffering to the bolts in the clamps around the sleeves? So now you can't spin the tie rod ends out of the sleeves?
Have you sprayed them with any type of penetrant such as PB Blaster. I usually clean anything that I am trying to get apart up with a wire brush first to get most of the crud out of the way first. Then spray with penetrant. With the sleeves, an extra little trick can be to hit opposite sides of the sleeve at the same time with a hammer. This will open them up a little. Of course a good "hot wrench", will also do the trick (a torch). Heat only the sleeve to expand it and have your pipe wrenches all set to the right size so you can give them a go as soon as you put the torch down. Make sure you wear gloves for this one.
If you don't have a decent torch set yet, you might want to make an investment as torches can provide the coaching that many a stuck part will respond to.
Old 12-27-2011, 01:02 AM
Thank you for your help. I got the clamps free, but I couldn't get the tie rod end out of the sleeve. I will definitely try the things you suggested. I wanted to make sure that it just needed an extra push, and not that there was some kind of trick to it.
Old 12-27-2011, 10:51 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Everything Spuredon said, but do you realize they are threaded into the tube? The clamp you removed tightens up the tube around the thread so it won't accidently unscrew.Is the assembly still on the truck? If you are working on it off the truck, keep in mind there is one right hand thread and one left hand. You will need a 'pickle fork' to remove the ends from the steering arms. You may have already done this. My whole tie rod assembly fell off on one side while I was rolling the truck off my tilt trailer because someone in the past had removed he castleated nuts and cotter pins, but I think you're gonna need one. If you can't buy an oxy-aceteylene set right now, get a regular propane type torch and a yellow mapp gas cylinder. Gets pretty hot and it worked for me for for a long time. Take your time and be thorough. Check for safety issues like missing nuts before you drive it again. At the risk of sounding like a 58 yr old 'old guy', I still shudder at what might have happened if I just got the 59 to run and then taken off roaring through the countryside to show my new find to my buddies like I have done somany times in the past. Oh what a feeling when when the front wheels suddenly have a mind of their own. Keep us informed how it's going and good luck!
Old 12-27-2011, 05:37 PM
spurredon's Avatar
Quote:
No problem, you could still turn the left wheel! LOL
MConnelly, you will have to set the toe in after you change them out. Not a super hard job but can be painstaking. Very essential though.
Old 01-02-2012, 07:58 PM
Thank you both for all of your help. I fought the ends for about an hour and still couldn't get them out. I will have to pick up the tools and I will update you when I have the tie rod ends freed and replaced. I just can't wait to get this thing completed. It's so much harder when I am trying to keep the original engine rather than dropping in a small block. Should have her running here soon.
Lowering Woes.......Help Needed filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 02-14-2017 08:46 PM
In need of a tie rod 1974 f100 4wd TheRedlines 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-27-2017 08:07 PM
Best tie rod ends? Which is Which? Anthony Polsinelli 1999 - 2003 7.3L Power Stroke Diesel 13 12-29-2015 05:24 PM
Are boots in steering linkage all the same? ssi9620 1987 - 1996 F150 & Larger F-Series Trucks 1 07-16-2015 10:27 AM
Tie Rod problems Kalahari south afric 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-22-2015 09:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
