Oil cooler tube leaking coolant? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-26-2011, 03:18 PM
HH60FE's Avatar
HH60FE HH60FE is offline
HH60FE has a very good reputation on FTE.HH60FE has a very good reputation on FTE.HH60FE has a very good reputation on FTE.
Visiting daughter out of town an I've developed a coolant leak. It appears to be comming from the oil cooler where it bolts to the front drivers side of the eng. Is there an O-ring in there? The two bolts seem to be tight. I also brought up the oil cooler cleaning pictures and there doesn't look like an oring on the cooler side. Gota get back home tomorrow. Prolly just get some 50/50 at flying J and drive on.
Thanks much.
Old 12-26-2011, 03:59 PM
1996pwrstrk's Avatar
1996pwrstrk 1996pwrstrk is offline
Wrench Party Assistant
1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.
Thats what I would grab a couple of gals. and stop and check it once in awhile, drive it back to the house and wrench on it there.
Old 12-26-2011, 04:07 PM
DieselOrings's Avatar
DieselOrings DieselOrings is online now
SPONSOR
DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.
There are two large o-rings on each end of the tube along with gaskets on each flange. It would be quite a job to try and do it on the road without your regular tools at hand but what you have to be concerned about is cross contamination of getting oil in your coolant and worse, coolant in your oil as it will destroy bearing surfaces quickly in your motor oil.
I have the complete cooler kit on my website.
__________________
Bob aka 'guzzle'
Specializing in Viton o-rings and leak repair kits for the 7.3L diesels
(970) 368-4455
guzzle's Mods & Maintenance website
Old 12-26-2011, 09:03 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
when doing this procedure, is it always necessary to purchase a new OIL COOLER or can the old one be reused? Is a full coolant flush required? I need to do this to my truck soon.
Old 12-26-2011, 09:11 PM
SPONSOR
If you live in the "salt belt", it would be a good idea to inspect the condition of the tube for corrosion pitting. If it looks bad then you should consider getting a new cooler tube but most will get away with just new o-rings and gaskets.
If you do not have signs of oil in the coolant or coolant in the oil, flushing would not be necessary unless you are planning on changing the type of coolant in your engine.
__________________
Bob aka 'guzzle'
(970) 368-4455
Old 12-28-2011, 01:08 PM
HH60FE's Avatar
Got the truck back home last night without leaking any more coolant. Guess it didn't like the cold Kansas weather and the gasket contracted after I shut er down and the system still had some pressure in it. Still need to get with Guzzle and order the seal kit to fix this properly.
Cooling system/oil system pressure question jpcjguy 1999 - 2003 7.3L Power Stroke Diesel 3 05-21-2015 08:59 AM
Fixed oil cooler o-rings today. What a pain!!! Firefighter 1406 1999 - 2003 7.3L Power Stroke Diesel 70 02-12-2015 06:03 AM
oil cooler leaking Jerry Chaney 1999 to 2016 Super Duty 4 12-31-2013 12:41 PM
Oil Cooler O Ring Change - Coolant in the oil pan JWink 1999 - 2003 7.3L Power Stroke Diesel 4 09-01-2013 08:27 PM
Oil Cooler O-rings? 85F250Diesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 05-06-2009 09:40 PM
Tags
73, aluminum, coolant, coolent, cooler, diesel, leak, leaking, losing, oil, orings, pitted, radiator, sport, trac, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
