Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 12-26-2011, 11:01 AM
fieldman2 fieldman2 is offline
1961 Ford F-100
fieldman2 is starting off with a positive reputation.
Bumpers for 1961 ford truck styleside
Have a question about rear bumper on 1961 ford truck styleside (Unibody), the origanal bumper has the dip for the license plate which I am not will crazy about. I have seen pictures on the web were guys have used looked like a rear 1964 bumper that had the indention for the license plate which I like better. Could anyone tell me how much trouble it would be to accoplish this and if I can use the bumper brackets that is on the truck will work or any other suggestions Thanks.
  #2 (permalink)
Old 12-26-2011, 04:45 PM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Garage is empty, add now
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
Hey there you are probably talking about what I think is called the sport bumper from 64 up. Here is a pic of it. As to how you get it mounted to your truck Im not sure. I did not look up under that uni to see how he accomplished that.
Click the image to open in full size.
It does look good back there. Just like that is the one it came with.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Vic by the way.
  #3 (permalink)
Old 12-27-2011, 08:10 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Sport is the idiotic name some of repro parts sellers are calling this bumper. It is not Ford terminology.
C4TZ-17906-B .. Chrome Contoured Styleside Rear Bumper / Reproduced
Applications: 1964/66 F100/250 2WD / 1966 F100 4WD / 1967/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79 F350's on the 140" wheelbase.
The bumper is the same 1964/79, but the brackets are not the same after 1972.
C4TZ-17787-A Right & C4TZ-17788-A Left .. Inner Bumper Brackets / Reproduced
C4TZ-17795-A Right & C4TZ-17796-A Left .. Outer Bumper Brackets / Reproduced
Styleside applications: 1964/66 F100/250 2WD / 1966 F100 4WD / 1967/72 F100/350.
There was also this: C4TZ-17906-A .. Painted Contoured Styleside Rear Bumper, same apps as C4TZ-17906-B.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 12-27-2011, 09:08 AM
1961 Ford F-100
Bumper
Bill the truck I have is a (1961 unibody or styleside) with the original rear brackets how much trouble would it be to install a bumper like what is in the picture instead of the one that came with the 61 that drops down for the license plate. The bumper in the picture has bolts in the top where the 61 has bolts in the bumper face but I like the one in the picture for my 61 if it is not going to be hard to confert any help would be appreciated thanks.
  #5 (permalink)
Old 12-27-2011, 09:55 AM
Ford Parts Guru
2013 Ford Escape
I'm aware you have a Uni, also noticed your ad in the Parts Wanted section for one a these later bumpers.
But, I have no idea what's involved. You'll have to find someone w/a Uni that has made this swap. There is no parts catalog ref, since this bumper was introduced in 1964 and Uni's were cancelled in 1963.
__________________
  #6 (permalink)
Old 12-27-2011, 10:45 AM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
You need to purchase the 64 to 72 bumper brackets and bumper. Each is reproduced by the aftermarket. The truck pictured has a reproduction bumper.
To mount it you will need to cut two slots in the rear roll pan to allow the brackets to mount to the outboard face of rear frame section. The 61 to 63 uni 66 frame is the same as the model 81 and is the same width. The brackets may bolt to existing holes in the frame, Maybe Maybe not?. Final Adjust accordingly to your lack of taste this bumper provides to the classic lines of the uni.
You will also need to rewire lighting for the license plate.
A fairly easy swap if you do not mind cutting up the rear factory roll pan.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #7 (permalink)
Old 12-27-2011, 12:26 PM
Buzz44's Avatar
I stand corrected Contoured is what I will hence forth refer to this bumper as. (note for Garbz) Beauty is in the eye of the beholder.
__________________
Vic by the way.
  #8 (permalink)
Old 01-23-2012, 05:01 PM
mark63uni's Avatar
mark63uni mark63uni is offline
mark63uni is starting off with a positive reputation.
Anyone have a link for a decent reproduction bumper like that?
Tags
1961, 1963, 1966, bumper, drive, econoline, f100, ford, rear, sale, sell, styleside, truck, unibody, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
