Rear end rebuild - Ford Truck Enthusiasts Forums
Rear end rebuild
Old 12-25-2011, 10:04 PM
Ken1098's Avatar
Ken1098 Ken1098 is offline
Ken1098 is starting off with a positive reputation.
Rear end rebuild
So I am pretty sure my rear end is having issues the rear tires locked up (one one way the other going the other way) on christmas eve at the inlaws. So tomorrow I am going to tear into it and see what the hell I broke. It is a 2001 F350 cc srw i believe it to be 3.73 gear dana 60 spliner... I could be wrong would not be the first time. What I am looking for is ideas from you guys on where to get good aftermarket parts for the repair. I would like to upgrade alittle but only if it is close to the same $$ as putting ome back in it. I may end up just buying one from a salvage yard depending on what damage was done. i was able to drive it home after it broke with a little bit of grinding in the rear end. Any ideas would be great but please tell me not just what to get but where I might go about getting to also. Thanks a million.
Old 12-26-2011, 07:54 AM
Robert6401's Avatar
Robert6401 Robert6401 is online now
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts
Clay can get you all the parts you want at the best prices. Theres not much better than OEM when it comes to R&P, but if you're thinking of regearing now's the time to do it.
Your rear-end is a Sterling 10.5", the Dana 50/60 is up front (most likely a Dana 50 with it being a 2001).
Good luck.
Old 12-26-2011, 09:04 PM
Ken1098's Avatar
Turns out just a spider gear broke it half. A local guy had all the parts for 60 bucks the oil was 80 though lol fixed and back on the road. Priced a detroit locker while I was there said 550 for the kit. maybe next time...
9inch rear end Ford_Guy123 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-08-2016 07:10 AM
Speedometer reading slow millerliteliker 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 02-01-2016 04:27 PM
Broke drive shaft yoke, bent other one UP77F250 1973 - 1979 F-100 & Larger F-Series Trucks 20 04-09-2013 11:46 AM
04' f350 suspension question FM20 6.0L Power Stroke Diesel 5 01-12-2012 09:33 PM
Timing Cover Stuck timboslice85 1987 - 1996 F150 & Larger F-Series Trucks 5 08-24-2011 11:19 AM
Tags
1997, 2001, 2007, 350, 73, end, expedition, f350, ford, fx4, kit, liter, rear, rebuild, rebuilt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
