89 F150 misfire and stumble? - Ford Truck Enthusiasts Forums
Old 12-25-2011, 08:31 PM
tacotanker27 tacotanker27 is offline
tacotanker27 is starting off with a positive reputation.
I've been a long time viewer and seldom poster on this forum for a while, but have finally found a problem that I haven't seen covered yet. I have an 89 F150 4.9L that has been misfire and stumbling hard at wide open throttle, and also has a rough idle. The problem is intermitent when cold, sometimes it does it and sometimes it doesn't, but when warmed up it does it 100% of the time. I've put a new o2 sensor, EGR valve, EVP sensor, TPS sensor, FPR, cap, rotor, plugs, and wires into in the last few months and still have this problem. I've checked the exhaust for a clogged cat and it showed no back pressure, cleaned the plenum, checked all vacuum lines for leaks, I tested the EGR vacuum solenoid and it opens when grounded, and right now I've pulled the injectors and have them soaking in cleaner over night.
The truck was driven up until around 2005 when it was parked in a field. The owner needed some work done around the farm and didn't have the money to pay me so I took the truck as a trade in 2009. Im certain the truck hadn't been run in the 4 years it was there because the battery was completely shot when I picked it up, but after replacing it it fired right up.
I've been hunting this problem for a while, it started out as a hardly noticeable misfire that I put off, but has escalated to where the truck is no longer safe to drive. I've taken it to a shop and they diagnosed it as the o2 sensor and possibly the injectors. I don't have much hope in the problem being the injectors as they looked in great condition when I pulled them.
Can anyone help me out with this? I've not a clue what else could be causing these problems.
Old 12-26-2011, 01:04 PM
Freightrain's Avatar
Freightrain Freightrain is online now
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
The injectors could be clogged/faulty and not firing properly and thus giving you a miss.
Sounds like you covered pretty much all the other bases.
Old 12-26-2011, 03:35 PM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
intake gaskets possibly
Weird stumble - right @ 1500 RPM illushinz Modular V8 (4.6L, 5.4L) 10 10-22-2016 01:27 AM
4.9 inline six misfire/possible demonic possession hangtownryan 1987 - 1996 F150 & Larger F-Series Trucks 23 10-17-2016 11:24 PM
Runs great, engine light blinks, misfire or mystery? rfmodulator 1987 - 1996 F150 & Larger F-Series Trucks 4 12-28-2013 10:23 PM
EGR valve symptoms? Mannix 1968-2013 Full Size Vans 14 07-23-2011 05:27 PM
Misfire after warmed up. Aeroman59 Aerostar 4 11-09-2008 07:20 PM
Tags
1987, 1996, 300, 351, 49l, 89, efi, f150, ford, idle, inline, misfire, missfire, stumbilng, stumbles, stumbling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
