What is a 4 bolt FE block worth ? - Ford Truck Enthusiasts Forums
Old 12-25-2011, 07:49 PM
Ken(Ark) Ken(Ark) is offline
Ken(Ark) is starting off with a positive reputation.
I have a 352 cid C4AE block with the webbing for 4 bolt mains . I have the center 4 bolt main and three #2/#4 main caps .
I have not had the block ultrasound checked and it has not been machined for the side bolts , of course it has not been line bore either .
I see a few 406 / 428 4 bolt motors made from this set up and was planing on doing something along this line or at least a 390 / 410 since the block is still 4.000" with no noticeable ring groove .
I am getting to the point that I like eating better than hot rodding and may sell the FE stuff and use the 289 crank in a 5.0 roller block for my 64 fairlane project .
I have been out of the loop for a while and was just curious about the FE value .
Thank in advance for any info/opinions - Ken.
Old 12-25-2011, 08:23 PM
DeepRoots DeepRoots is online now
DeepRoots is gaining momentum as a positive member of FTE.DeepRoots is gaining momentum as a positive member of FTE.
I've got one of those C4AE 390 standard bore block with the cross bolt bosses and main webbing.
I'd value it at $200-$250
I've also got a D4TE block that has roughly the same bottom end, standard bore but obviously with different engine mounting provisions.
I was keeping them around for future stroker platforms.
for a 352 block? I personally would value it as scrap metal prices, so $20?
Good luck!
Drew
Old 12-25-2011, 09:55 PM
Good luck!
Drew
Ha ! I see you aren't a 352 fan , neither is my Dad .
I really need to have the block sonic tested but I would think it would easily go standard 390 of 4.050 . I have a boring bar and any V8 block ready to go is $250 .
I would probably be better off selling the caps on ebay , as I have seen them go for $100 each . I would not have guessed that much but I guess the FE guys are nuts .
Your 390 block should easily double that price in a few years. Around here scrap iron was selling for .12 a pound . There has been a run on those mid 70's pick ups (Ford & Chevys) since the scrap yards are paying $400+ regardless of the number of dents .
Just thought I would see if anyone had any real time experience with the subject - Ken .
Raptor at BaldFace, BC Keeseter CO 2010 - 2014 Ford SVT F150 Raptor 0 10-08-2014 03:30 PM
393 stroker motor for sale 1966_F100 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 09-14-2014 11:26 AM
fe 390 in 73 f250 camper special jeff14346 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-30-2011 09:20 PM
391ft flexplate to replace 390fe on C6 abc2129 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-11-2011 09:02 PM
Solution to ARP rear main cap clearance. maxtor FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 04-16-2009 02:33 PM
Tags
352, 46l, block, blocks, bolt, c4ae, crankshaft, cross, engines, fe, ford, forged, main, sale, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
