6.0 with 6 speed manual transmission for towing - Ford Truck Enthusiasts Forums
Old 12-25-2011, 07:30 PM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
Fellas,
I am considering buying a 2005 6.0 50000 miles 4x4, long wheel base, with 6 speed manual transmission. Primary purpose for buying the truck would be to tow my future 5 th wheel camper.
Does anyone have any experience with this truck? I have a 05 short wheel base 6.0 and very familiar with these engines... Just never messed with the manual and would love to have one. The truck is my dads and is all factory, no problems, and is in immaculate condition... Would just be an awesome truck to have.
Pleas give me your opinions. Would it tow much better than my current 6.0 with an automatic? I believe I have 355 andthis one has 373 rear end.
Thanks
Old 12-25-2011, 07:32 PM
Posting from my iPhone, forgive me for the butchered text....
Old 12-25-2011, 08:04 PM
77-250 77-250 is offline
77-250 is starting off with a positive reputation.
The truck in my sig is a 6 speed, 2006 F350. I guess you could say I'm from the "old school" thinking a truck should have 3 pedals. I've heard too many bad things about automatics in trucks, and have had some experience myself. But I do believe the automatics in the 6.0 are pretty good. I wasn't fully happy with the throttle response of the stock tuning, it was too much geared toward emissions. So if you want it to drive like a P pump Cummins, you are going to want a custom tune, but I wouldn't do it without head studs. Either way, the ZF6 is a great transmission. It shifts pretty good, clutch is decent, and its got full pressure lubrication and an oil cooler. When its time for a new I'll probably go with a F550 flywheel and clutch.
Old 12-25-2011, 09:04 PM
Crash16 Crash16 is offline
Crash16 is gaining momentum as a positive member of FTE.
I wouldn't trade my zf6 for anything. I only towed about 12k lbs, but even with that is was smooth. I had to replace my clutch at 120k miles, but I was pushing 800 ft lbs of torque through it. I went with the upgraded south bend dual friction clutch and I couldn't be happier with it.
Old 12-25-2011, 09:06 PM
Thanks for the feedback, I really want this truck!!!! I am a little different than most, this truck is plane Jane.. Cruis and tilt steering other than that it is plane. Perfect, no carpet to mess up. Will be a nice machine to have!
Old 12-25-2011, 09:09 PM
Also, if I get it i will probably go ahead with and bullet proof it ( studs, delete ect...)
Old 12-25-2011, 11:12 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Mine is a 2004, not a 2005, but I still like the 6 speed. About the only time I don't like it is in heavy traffic with a heavy load and my clutch leg wears out. Other than that, it's a great transmission.
It's a BIG transmission. And you won't speed shift it. At least I can't. Just take your time and put gentle pressure on the shifter and it'll drop in after a few seconds. It gets better after it warms up and it gets better after it wears in a few 10k miles.
Old 12-26-2011, 01:09 AM
dukie1877's Avatar
dukie1877 dukie1877 is offline
dukie1877 is gaining momentum as a positive member of FTE.dukie1877 is gaining momentum as a positive member of FTE.
My grandpa use to race fords in the 30s so my dad was raised in a ford family and that got passed down to me. But I remember as a kid my grandpa use to buy his trucks new after he retired and when it was time for him to upgrade my dad would always buy his trucks from him. The reason being that he knew that his dad kept great maintenance and drove the truck how it was made to be driven and dident abuse it. All I can say is between the two of them they did well and So did I after buying a 1985 f-250 4x4 and selling it in running condition and a 1993 f150 4x4 with 200k that only ever had a starter burn out. Point being is buy that sucker if you know your dad keeps good maintenance. Thats my opinion.
Old 12-26-2011, 01:24 AM
Agree! I'll do what i can to get it. Thanks for the input!
Old 12-26-2011, 10:06 AM
What kind of maintenance is required for that transmission?
Also, will it tow much better than the automatic? Thanks, getting siked thinking about this!!
Old 12-26-2011, 10:25 AM
Jimbob8's Avatar
Jimbob8 Jimbob8 is offline
Jimbob8 is starting off with a positive reputation.
Just serviced my 04 350 the other day, 160k don't know if it had been done before only had it for 30k, but oil was clean & no burnt smell, put it in low it will move about anything!
Jim
Old 12-26-2011, 11:27 AM
Thanks jimbo!
Old 12-26-2011, 11:36 AM
mhoefer's Avatar
mhoefer mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
I think you will like the manual for towing. The only downside is the speed of shifts on hills towing heavy, you can't shift fast enough to not loose some boost, like an auto can. Other than that, tranny is heavy duty. There are still times I wish had ordered my lariat with a stick. I know a friend has had good luck towing the horses heavy with a stick, they both drive it and like the manual. One clutch and throwing bearing down. Remember, don't leave your hand on the stick when not shifting and don't ride the clutch pedal as these will cause premature wear of syncros and clutch. They are really quite common. Also, remember you have a lot of power so, before pushing the go pedal to the floor, that clutch has to be fully reeleased, she will smoke a clutch very quickly. Have fun.
Old 12-26-2011, 11:51 AM
fluidp fluidp is offline
fluidp is starting off with a positive reputation.
Have a 06 f350. Love the manual. Mileage is great when towing or not. You have full control over engine rpm's which you don't have wit the auto. The only problem I have with mine is the throttle response when shifting, combine that with a sticky turbo, well its a pain in the *** once and a while,
As far as maint, Mercon V only, every 60,000 miles.
Does anyone have any insite into the manual trany for the new superduties one day????
Old 12-26-2011, 10:03 PM
IHbase's Avatar
IHbase IHbase is offline
IHbase has a good reputation on FTE.IHbase has a good reputation on FTE.
The ZF transmission is excellent. The oil cooler is a great design. I've run down the freeway with 23,000 lbs on a 9,000 lbs trailer with no concerns about the transmission. Downside: You lose boost between shifts- the 6.0 likes to be at full boost when pulling. And fully loaded at 3,000 RPMs, the 6.0 is NOT a smooth power plant. But it sure does pull. As long as it has not been hammered by the previous owner, I would not hesitate to go with the ZF sp. -Mike
Recommened Towing Speeds? PatrickNDT 1999 to 2016 Super Duty 27 06-12-2014 05:03 PM
HELP!!! 6.0L vs 6.4L Peter James General Diesel Discussion 4 04-18-2014 11:38 AM
HELP!!! 6.0L vs 6.4L Peter James 1999 to 2016 Super Duty 17 04-17-2014 11:58 PM
4-Speed Manual to C6 Automatic Transmission Swap Nightrain 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 01-31-2013 12:49 PM
Ranger 4.0 pathetic towing capacity? JefFZ6 Ranger & B-Series 14 06-08-2010 10:33 AM
Tags
06, 2004, 60, 6speed, convwrsion, f350, ford, good, lightning, manual, tow, transmission, transmissons, truck, zf6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
