Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- Radiator Reviews
Reviews and comparisons of top products
Busted radiator
Busted radiator
So, my radiator popped a pretty bad leak on the top end and is leaking coolant at a pretty good clip. I am going to replace the radiator and there are several different options but I need to understand the differences. The radiators from Oreilly are around $300 they are Murray radiators and have a Copper/Brass core. The ones from Autozone are the same price but have Aluminum cores. Then I found one from JC Whitney that is $120 and has an aluminum core and a plastic "end tank" (what is an end tank).
I would assume that the Copper/Brass unit from Oreilly is probably the way to go but why would the one from Whitney be so much cheaper? What is an "end Tank" and would I be taking a significant risk by getting the $120 unit as opposed to the more expensive ones?
Here are the links to oreilly and whitney:
Spectra Premium Replacement Radiator - JCWhitney
Murray 432194 - Radiator | O'Reilly Auto Parts
Ok here us the deal with the radiator delima, copper and brass are way better conductors so they are obviously a better material for a radiator. I replaced mine about a week ago so I have some insight into this topic. The tig welded aluminum ones with aluminum tanks are made in usa and will not rot like the copper and brass ones that have about a 15-20 life span due to the brass getting soft I went with the all aluminum radiator for quality however I have noticed a difference in the cooling, my truck will move the gague a small amount when I pin it going up a long grade that it never did before with the copper radiator. So go cooper if you are going to do a lot of hauling, go aluminum for price and longevity
