How to adjust the steering gear box? - Ford Truck Enthusiasts Forums
Old 12-25-2011, 12:58 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
I know I will have to loosen the nut and then use a flathead driver and turn but my steering still feels a little loose even with my new steering shaft. How can I go along and make the steering tighter by adjusting the box? Do I turn the screw left or right or what?!
Old 12-25-2011, 01:58 PM
devino246's Avatar
devino246 devino246 is offline
devino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputation
After loosening the nut, you'll probably have to put a combo wrench on it so you can turn the bolt with a screwdriver without turning the nut. Hard to describe, you'll figure it out. Turning right will tighten everything up. Do a little at a time, and then turn the wheel lock to lock to make sure it doesn't bind.
Old 12-25-2011, 02:08 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Make sure it's full of grease. If you can't adjust the slack out easily, it's time to rebuild or replace the box. They don't last forever.
Old 12-25-2011, 02:13 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
The adjuster screw is setting the position of the sector shaft in the box, the sector shaft has tapered teeth on it so the backlash between the worm and the sector changes as the sector is adjusted, most of the wear occurs where the wheels are aimed straight forward, whenever you adjust the box, make sure you crank the steering to the stops in both directions, snug in the middle may be too tight at the ends, i like to put the front axle up on jack stands and do it with the engine off, the power steering boost makes it hard to feel it binding.
Old 12-25-2011, 03:12 PM
fitzmotor's Avatar
fitzmotor fitzmotor is offline
fitzmotor is starting off with a positive reputation.
If you get it too tight it will have memory steer, that is where when you turn the wheel slightly off center when driving straight it wont return to center.
Old 12-25-2011, 04:15 PM
wyckedcombo17's Avatar
wyckedcombo17 wyckedcombo17 is offline
wyckedcombo17 is gaining momentum as a positive member of FTE.
Not sure which box you have, but first you need to adjust the preload on the worm gear shaft. Once that is okay, then check your sector shaft backlash. I'm not sure of the specs cos I'm out of town right now, you'd have to look in your Haynes manual or something.
Old 12-25-2011, 08:25 PM
Well I turned it to the right some; seems a little better but still wondering some; I probably didn't turn it enough or done it right. Will carry it to a mechanic in the morning- IF they are open.
Thanks guys.
Old 12-26-2011, 08:24 AM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
Adusting will get some slop out but won't fully compensate for wear. I've been able to get "a little better" by adjusting but never "just right". Too much adjustment will hurt the box and cause other problems. It may be time for a rebuilt box.
Old 12-26-2011, 10:51 AM
Well I got a new steering gear box but I just came back from the mechanics. They say the box is good. They pointed out that my worn out shocks would be a problem and there is like a center link (but it's connected to the axles instead of the steering components) that moves...looks like the bushings in it are worn out. Will that cause a problem?
I am also running 38s and they mention I have a small steering wheel which could cause it to feel weird.
Old 12-26-2011, 11:03 AM
gfw1985's Avatar
Cranky Old Guy
Any bushing in the front end can cause problems. Each little bit of play compounds things. The fact you're running 38's is going to hard on everything and make any weakness show up more. Even with everything in good working order, properly aligned, type tire and air pressure can cause wandering.
Old 12-26-2011, 11:08 AM
Well; looks like I need to get some new front shocks and get them little bushings for that bar (don't know what that bar is called)
steering box adjustment? texasjack 1999 - 2003 7.3L Power Stroke Diesel 17 04-07-2015 11:14 AM
77 f250 steering play help 77429highboy 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-19-2011 09:58 PM
Steering box on 07 F250 PSD bm7788 1999 to 2016 Super Duty 5 01-11-2011 09:18 AM
Steering box adjustment. 79FordBlake 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-17-2010 01:13 AM
Adjusting steering box M6EV139445 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-23-2006 11:09 PM
Tags
1979, 4x4, adjust, adjusting, adjustment, box, courier, f100, ford, gear, gearbox, screw, sector, steering, truck, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
