Misfire, no codes
Today, i have now removed all the spark plugs and coils, in 4 hours, without disconnecting the rails.
All spark plugs were fine (visual control) and there was a spark at all coils.
After reassembling, when i disconnect one coil after another, there is always a speed reduction at each disconnected coil.
And ther are only 7 cylinders firing...
I will now go change every spark plugs and the rubber grommets on the coils as well.
Is it possible that this effect may incur in disguised tax time (timing chain problem?)?
A weak spark will still fire at idle but will fail under load, such as when accelerating. This is why you're seeing a change in the engine when you disconnect each coil. The easiest way to find the faulty cylinder is to use a scanner that can read live data as you drive. The live data from the scanner will show a misfire count per cylinder.
Dani, the misfire could also be an injector problem. You will need to identify the problem cylinder using a scanner. If you want a professional scanner I suggest searching ebay for a Snap-On, Mac or Ford dealer unit. With the Ford unit you will be able to do much more than just read codes
Today I made the action again ... COP's out, spark plugs out ...
(Bevore, i had a code P0353, but no cylinder.... )
Contrary to my assumption, not a plug was wet, although only seven cylinders have fired!
This points toward my humble opinion, a defective injector or a power problem in the supply line ....
Here are a few photos. For more pictures here
1.5 hours for the removal of the spark plugs and COP's with built-in Rails
Today i looked for the codes with professional equipment.
But there is no code at all....
Every plug is ok, every coil is ok...
Now i have to check the injection valve, but in fact, i dont know where else to search to find the problem...i'm just a "hobby-mecanic" at least...
What else can affect my problem?
Dani, at one time I had a mystery miss in my truck and the problem turned out to be this;
Duralast/Crankshaft Position Sensor
For your 2000 Lincoln Truck Navigator 4WD 5.4L SFI DOHC 8cyl
Price:$22.99
Part Number: SU256
AVAILABILITY:
STORE PICK UP
AVAILABLE
Normally stocked at your local store.
SHIP TO HOME
AVAILABLE
Ships within 2 business days.
ADD TO CART
Eligible for FREE 2-Day Shipping
learn more | sign in
Features & Benefits
Duralast products are engineered and manufactured by Wells Manufacturing, a leading global supplier of advanced vehicle electronics solutions for original equipment and replacement applications. Every component either matches or improves on the OE design to ensure fast, easy installation, superior performance and reliability. Wells offers extensive application information and technical support via its Tech Line at 1-800-558-9770, as well as in-depth product and repair videos on the Wells web site or on the “Wellstech” channel on YouTube.• The crankshaft position sensor identifies position of the crankshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM)
• When not replaced, vehicle could experience no- or hard start, long crank time, misfire, lack of power, excessive hydrocarbons in oil, spark plug fouling, catalytic converter failure, poor fuel economy, CEL/MIL illumination or intermittent shutdown
• Designed to meet or exceed OE specifications in form, fit and function
• Global coverage for import and/or domestic applications
Part Number:
SU256
Weight:
0.1 lbs
Warranty:
Limited Lifetime
Connector/Terminal Type:
Female
Package Contents:
Component Only
Remanufactured Part:
No
Shipping Information:
Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Price:$22.99
Part Number: SU256
AVAILABILITY:
STORE PICK UP
AVAILABLE
SHIP TO HOME
AVAILABLE
ADD TO CART
Features & Benefits
Part Number:
SU256
Weight:
0.1 lbs
Warranty:
Limited Lifetime
Female
Package Contents:
Component Only
No
Dean Ledgerwood
Escape & Escape Hybrid
24
01-25-2021 06:49 PM
4x4pwr
02-15-2015 09:14 PM
