What a Bog
What a Bog
So I had a previous thread about a hard start problem I was having and we fixed but I have a new/old problem. I set everything, on the 292 f100 with 2 barrel holley and electronic/vacuum mallory dizzy, to the normal settings. that is I have the initial timing at 10, the idle screws 1 1/2 out, and the idle speed screw so that the transfer slot had just the square showing to try to eliminate a bog I got whenever the accelerator was initially hit. The problem is that with the idle speed screw set for the transfer slot it has the engine absolutely running away from itself at like 3000 rpms. So I crank it back to 800rpms and it runs nice except for the bog is there when i first step on the accelerator and if I dont let up it will die. So off the line or when turning corners I have to really ease the gas or get on and off and then back on again. What am I doing wrong that the transfer slot setting has this affect? and or what can I do to fix the bog? Thanks for the help, I hope to get the same result as the hard start, that is fixed thanks to you guys, and the y-blockforever siters.
Cbass
Cbass
This might be a good place to ask carb questions, also:
Ed's Carburetor Forum. Carbs rule!!!!
Another member told me about it,I can't remember who, though.
From Holley: You can try a higher # (larger) pump shooter size. The bog or hesitation may be caused by a momentary lean condition when the carb goes from the idle throttle position to the main metering system. The shooters help richen this momentary condition and eliminate the stumble. Keep going up in shooter size until a puff of black smoke comes out the exhaust, then go back one or two sizes.
Ok, here we go. I went to the parts store and ordered the stuff I thought I might need to get this all done and fixed for good. Of course the parts are not in stock but they would have them tomorrow, so I went home to double check everything I could so that I would have a starting point. In doing so I got the timing dialed in perfect and the idle where I want it and gave it a shot with the accelerator pump and noticed it shot right away but did not look like it was getting full travel. I went to adjust the screw and check the gap at WOT and the screw was completely loose. I tightened it down and checked the gap, started the truck back up and sure enough with full travel that girl runs like a dream. I thank everybody that gave advice and say to you all to double and trip check everything even stuff you are sure you had working great a few months or weeks ago.
Thanks a ton and have a great New Year.
Cbass
Cbass
ez1134
05-23-2017 06:44 AM
lvin4jc
27
01-02-2017 05:10 PM
Hogtrapper
43
10-13-2013 09:17 PM
The_SnowMan710
34
12-29-2010 04:01 PM
jwtaylor
09-24-2003 07:53 PM
