Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-24-2011, 12:59 PM
lance65's Avatar
lance65 lance65 is offline
Garage is empty, add now
lance65 is starting off with a positive reputation.
2wd to 4wd?
I know that I will need a transfer case,but my question is......I have a '59 F250 2wd and I want to convert it to 4wd. Are the leaf springs different or in different locations on a 4wd than a 2wd? Will I be able to bolt up a D44 from a later (75-79) F250? Thanks.
  #2 (permalink)
Old 12-24-2011, 02:15 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is gaining momentum as a positive member of FTE.
Lance
From my limited experience the springs and mounts are the same except there were two choices for weight capacity for the front axle, making a difference in number of springs for the 250's. If it was me I"d chose the reverse or high pinion D44. If you have the illustrated guide for these trucks it will show the extra mounts needed for the divorced transfer case. If thats the way you are going? Good luck with your project keep us posted with pictures please!
Wally
__________________
1959 F250 4x4
Wally
  #3 (permalink)
Old 12-25-2011, 03:20 PM
hotfalcoon's Avatar
hotfalcoon hotfalcoon is offline
1957 Ford F-100
My Garage
hotfalcoon is starting off with a positive reputation.
The dana 44 from a late 70's F-250
will bolt in the same place as the stock axle
but the newer trucks have wider springs so
you will have to use spacers on the original
springs to make up the difference.
  #4 (permalink)
Old 12-25-2011, 08:13 PM
lance65's Avatar
GREAT! Thank You guys.
  #5 (permalink)
Old 12-27-2011, 08:24 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
One thing to be careful of is that Ford made some big changes in the late 77 F250s. I would say that you could use the the front axle (Dana 44) up to early 77. Frame width changed in mid 77. Whatever year axle you use, just make sure the distance between the index holes on the spring pads on the axle matches the distance between the spring center bolts of the front springs.
  #6 (permalink)
Old 12-27-2011, 10:29 AM
FORD14TPU's Avatar
FORD14TPU FORD14TPU is offline
FORD14TPU is gaining momentum as a positive member of FTE.
I did this build on my 55 F250 using donor parts off a 75 F250 4x4..Found a deal on all 3 major assemblies..Front axel/rearaxel/Tcase/driveshafts..From what i learned measuring endless axels was to use the closed ball axels up to mid 70s.. the open knuckle/disk brake axels are all wider frame..i addressed the wider leaf issue by welding small side plates on the top spring saddle plates that the U bolts seat on..
  #7 (permalink)
Old 12-27-2011, 03:00 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
imho steering is going to be your biggest problem. spring pads would be the easy part. i assume you have the drag link off the left side frame rail. an ideal situation would be to find an older complete donor with a closed knuckle dana 44, t-case and rear axle.
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #8 (permalink)
Old 12-28-2011, 01:13 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
Good bet for an almost direct bolt in swap. Look at the years 59-72 F250 4x4 or F100 4x4 up to 65. Changes where made in 66 to the F100 4x4 front suspention. It went to a coil spring front suspention and away from the leaf spring that you are looking for.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Vic by the way.
  #9 (permalink)
Old 12-28-2011, 12:11 PM
bunchoftrucks's Avatar
bunchoftrucks bunchoftrucks is offline
bunchoftrucks is starting off with a positive reputation.
Ford used the same frame from 1960 thu 1965 for F-100 4x4's and 1960 thru 1966 for F-250. Thats why they all had the "wrong" bed on them. The wheel base of 120 inches (4x4) versus the 129 (2x4 and 66 F-100 4x4) for long beds is the reason the beds were used for so long. 1967 all ford picks to F-250 shared the same wheel base. So if you can find a 60 thru 66 F-250 4x4 for a donor you get all the parts and mounting locations you'll need.
  #10 (permalink)
Old 01-05-2012, 10:47 AM
1967 Turbo 6.9 1967 Turbo 6.9 is offline
1967 Turbo 6.9 is starting off with a positive reputation.
Not to hyjack but how bad would just swapping the 59 body to a 77&1/2 or new frame with the better steering, brakes and all be?
__________________
1967 F350 6.9 Diesel Banks Turbo GV overdrive
1973 F250 camper special Linda Lou
1974 F100 4x4 survivor never been touched
1974 F100 6.9 Diesel 2003 Crown Vic front
suspension 79 grille
  #11 (permalink)
Old 01-05-2012, 11:36 AM
He would have to change the wheel base and body mounts, steering column etc. for a 77
  #12 (permalink)
Old 01-05-2012, 12:34 PM
Buzz44's Avatar
There is a frame width change somewhere in the mid 70s. Im not sure which year the change was made. I have seen it noted in NumbersDummys post. It would probably be alot easier to convert on a 4x4 before that frame width change. I have not done one myself so cant tell you how hard or what would be involved to do that swap. If you are looking for a direct bolt on I doubt it.
__________________
Vic by the way.
  #13 (permalink)
Old 01-05-2012, 01:49 PM
montego69 montego69 is offline
montego69 is starting off with a positive reputation.
Chassis Not So...
Quote:
My 60's chassis is level front to back with the only exception being the front couple inches right at the bumper. My 62 F100 4X4 has a step under the passenger compartment so the frames are not the same. Maybe you meant 61 and on but put 60 in by accident. Just thought I'd clear it up a bit.
This elevation change in the chassis affects the brackets/crossmember that carries the transfer case. I have pictures if anyone's interested.
By the way, I turned my '60 Fridge into a 4X4 using '62 parts but found that a 57-60 Fridge chassis needed to donate some 4X4 specific parts to avoid cobbing in some sort of custom crossmember.
Nick in WI
  #14 (permalink)
Old 01-05-2012, 06:26 PM
See what happens when you quote books. The reason that I shared that info was that Ford first factory produced a 4x4 in 60 and have read that the frame didn't change for 1/2 ton till 66 and 3/4 ton till 67 now I know better , thanks for the info. That's what I like on here I'm learning all the time ! I just went out and looked at my 64 and the frame is flat from the rear to the front of the cab, from there it slants upward a few degrees to go over the front axle to the front, go figure.
  #15 (permalink)
Old 01-05-2012, 10:24 PM
Buzz44's Avatar
I have read that the first Ford built 4x4 was model year 59
Before that it could have been made into a 4x4 by NAPCO or MarmonHarrington. Im thinking most I have read about the Marmon was Ford and the NAPCO was GM.
When they say frame did not change they were probably talking about the width between the frame rails.
__________________
Vic by the way.
Tags
1966, 2wd, 4wd, 66, 70s, f100, ford, series, truck, wd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
