1996 7.3 occasional rough idle
I have a 1996 7.3 with 125K miles. I only drive it on weekends and put about 5K miiles per yeasr. I try to keep up with the regular maintenance. I year or so ago I had all of the glow plugs changed, due to hard starting in cooler weather. I do try to use fuel additive due to not going through alot of fuel and also keep a clean fuel & air filter. On occasion, I do notice a rough idle, but it seems to come & go and sometimes appears when the engine is cold, and sometimes when I've been driving for a while. While this is a vague issues, are there any obvious past issues with these engines, to check first?
A small fuel leak will produce a rough idle. Even the smallest leak will suck a little air into the system and produce a rough idle. Not changing your oil in these trucks will make them idle rough. The motor oil is used as hydraulic fluid in the HEUI system. This causes the motor oil to become aerated after a few thousand miles and doesnt work as the hydraulic fluid very well.
Gary Staves
18
02-28-2017 10:28 AM
true blue
02-27-2011 06:51 PM
