1987 F-150 302 V-8 EFI IAC MOTOR - Ford Truck Enthusiasts Forums
Old 12-24-2011, 11:28 AM
dcape dcape is offline
dcape is starting off with a positive reputation.
Hello everyone.
After reading several postings on the subject of IAC motors and rough idle I am considering changing my recently purchased after market IAC motor from Advance Auto Parts to a Motorcraft IAC motor. I have tuned the engine, replaced the TPS, fixed vaccum leaks, ect. Unfortunately, my 87 F-150 302 V-8 still has idle issues. I have yet to change out the distributor cap, coil or rotor. Any help on this subject would be greatly appreciated. Thanks as always.
Old 12-24-2011, 12:58 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Did you pull any codes?
Old 12-24-2011, 01:19 PM
I will be pulling codes on Monday to see what may be present. After that, I will let you know what I find. Thanks and have a Merry Christmas!
Old 12-24-2011, 03:18 PM
f-150_1993's Avatar
f-150_1993 f-150_1993 is offline
f-150_1993 is starting off with a positive reputation.
well even new IAC's are bad, I have an aftermarket one and its a bit weird but whats it doing? it wont idle right? you should pull codes and secondly if you have the time you should remove the throttle body and clean it. Could also be the throttle position sensor. Gotta do a tune up if you haven't in a while so you can start eliminating from there.
Old 12-24-2011, 03:49 PM
Help
I have replaced the TPS and cleaned the throttle body, ect. Hopefully when I pull the codes on Monday I will have a better idea of what is going on. The vehicle takes a moment to start and the idle has a tendency to die shortly after starting. Eventually, once it gets running it levels out to around 750 rpm but it takes several minutes for this to occur. Any other suggestions would be greatly appreciated and a merry christmas to you.
Old 12-24-2011, 04:05 PM
f-150_1993's Avatar
Merry Christmas to you too, and umm well I really want to see what effect changing the plugs will do, coils tend to fail when they are hot and this is not the case lol. Fuel pressure got to check that out!
Old 12-24-2011, 04:19 PM
Help
I will change out the fuel filter and see if that helps. This truck was won by myself off of an EBAY auction for $670.00 It had been setting up for years in Kansas and was a one owner with the original Ford glass,white camper shell, ect. Man, was it dirty and filthy but it cleaned up rather well. I ran several bottles of Sea Foam thru the vaccum line and it seemed to help a little.
Old 12-24-2011, 04:21 PM
f-150_1993's Avatar
cool cool, what is the mileage on it? I am in need of an engine overhaul, but don't know if ill rebuild the motor or swap in a 351.
Old 12-24-2011, 04:45 PM
It has 230,000 miles. Two tone blue and white. XLT Lariat with original cosmetics. Factory radio and speakers jam!
Old 12-24-2011, 04:48 PM
f-150_1993's Avatar
NICE! lol welcome to the 200k mileage club, mine has 205k and still running strong. Hope you get it running asap they are fun
high idle issue...help please! troubled1 1987 - 1996 F150 & Larger F-Series Trucks 15 08-24-2016 05:12 PM
IAC Fifty4F100 Modular V10 (6.8l) 7 05-10-2015 09:52 AM
IAC Questions MacPhly 1999 to 2016 Super Duty 4 03-18-2015 09:03 AM
IAC Trouble bkbkbkbk Ford Inline Six, 200, 250, 4.9L / 300 3 09-07-2014 08:08 PM
Iac stuck open. brandonnichols 1987 - 1996 F150 & Larger F-Series Trucks 2 03-26-2014 10:21 AM
Tags
1987, 1993, 1999, 302, air, clean, control, ect, f150, ford, iac, idle, motor, motorcraft, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
