2007 Supercab Power mirrors and overhead map lights not working
I have checked the fuses, Checked the relays, Checked for pinched wires and checked for a loose connection at the fuse box, Both power mirrors and the overhead console lights do not work, Power windows work fine, Manual seats .
Any thoughts greatly appreciated.
I have pulled the overhead console down and checked the bulbs and they are fine, I also pulled and checked the switch for the mirrors and tested with an ohm meter and the switch is fine.
Hoping someone out there may have had a similar problem and has an idea what the source of the problem is.
