I got a 89 ford from a friend with no engine in it. I'm getting ready to install one and i was wondering if i can get some pics of the engine bay for some reference points on where some of the oddball stuff goes. thanks alot
a lot of that "oddball stuff" can be torn out or not re-installed. everything associated with the air pump can be removed with no adverse effect. this turns out to be a ton of stuff, especially if its a 5.8 truck.
you'd be amazed at the size of the pile of vacuum lines, hoses, and contraptions that you'll have after removal. . .and your engine bay will be much cleaner.
